19,992
Well the Flood Alarm went off today, as the tide started to lap at my feet, the flush button on Dunny had jammed, quick race outside water turned off then because of a mod done many years ago it was only a matter of open the door to access the fuse for the solenoid .......... perfect end to a really crappy week, mopped up the water, cupboards, toilet box, back of fridge all mopped out, doors, hatches and windows open, so looking like we got away without damage, sort the problem out when we get home but the Brides look at me got me thinking so after a cup of coffee, I dismantled the switch panel, fixed the mongrel thing and we now have a flushing toilet that won't do it again as I found the problem .................. And after a really sh*tty week, an absolute mungrel really my MoJo is back ............................................. on mains water thats why never knew till my toes were wet.............................. switch panel cover label sticky bit possibly had shrunk a bit so not allowing the push switch to return to off position ...............
Sparksy
14
10
After a incident where the solenoid jammed open , I fitted a isolating valve in the supply water line under the floor.
On a side note , if your toilet is a Thetford, the solenoid valves are the same as a Fischer Paycal 12v washing machine solenoid and are about $25 on ebay instead of the $80 that thetford want. When replacing it I also moved it from under the bowl and mounted it just inside the door. Why they designed it so you had to dismantle the whole bowl assembly to swap valves is a mystery.
19,992
I dismantled the level indicator and other rubbish years ago, just pulled it all out and binned it, so the solenoid is all thats left with fuse just inside the door if needed ........ I like that mod certainly easier of it fails...
Mine has a T piece just under the floor there so I could just slot a tap there but pulling the fuse by the door is just as easy..............
19,992
Bugga me, things are breaking left right and centre, Jeep fell over, Garage Door had a hissy, Security Cam dropped off line, replaced Jeep, fitted a new drive belt to door and managed to fix the power problems for the cams, now Big Mal decides the AC needs some attention ............. Went to check it out but before I started to remove the dozen screws to lift off the shroud, I got my ladders and tools sorted and discovered it has been many, many years since I tested a Capacitor, my multi meter must be at least 12 years or more old and I find it doesn't have the function, so that changes things but after getting up on the ladder to check the external fan operation I decided its time to call in a AC mechanic, some idiot surrounded the unit with solar panels so getting to the shroud will be hard enough let alone at the internals ......... my diagnosis is Capacitor as on cool the internal and external fans are fired up but no compressor kick in, on Heat it just does nothing no fans at all so this dumb truckie reckons capacitor or the compressor has totally died but money on the capcitor, whatever something cheap .........
I think it gets used more on its 3 monthly test run than while actually camping, if its just a capacitor will get it fixed but otherwise won't bother 98% of our camping is off grid and it mostly gets used in Canberra for Xmas visit's, might even remove it, 45kgs saved and replace with a roof vent affair... 2026 Big Mal is into its 15th year so resale isn't an issue ..... This IBIS Mk 3 was fitted in 2018 after a hail storm, nice unit but like all useless as a heater, the diesel works far better and often on our travels................
See what the AC Doctor discovers................
19,992
Well trying to get a RV AirCon mob to answer their phone is impossible around here .................. Got my gear out, borrowed a meter, tested the capacitors and the buggas are withing limits, fired it back up and the compressor actually kicked in for a second then shut off so something is stuffed, beyond my pay grade so will stay that way for awhile now. ....... $2K for a new one so might be the more economical way to go, just need to borrow a gantry...
  • Wow
19,992
A touch of Old Timers struck yesterday, as it seems I did a micky verta on the figures for the capacitor, I'd written 46-77uf which did seem strange at the time, it should have been 64-77uf so the test was a fail as it was well out from the +-10%, of course all the usual places seem to have nil stock I managed to find one in Melb so hopefully it will be in the mail express post on Monday, it has a resistor across the terminals so seems a rare breed which attracts the big $$ of course ................ Will my luck produce a winner or just more pain .................... Next week.
  • Wow
Reactions: DRW and chartrock
19,992
New capacitor turned up so confirmed old capacitor was knackered, fitted new one, fingers crossed, fired it up, left it running came back and temp at 27c, bum, must be something else thats dicky, I have thought it might be a relay thing but with no decent wiring diagram to be found, I'm not going to lay on the roof anymore playing blind mans bluff, not up to speed on this stuff anyway, besides its rarely used when away, Chris was saying she thinks it got used ast seriously in 2022 at Texas so that would have been with the genny, gets more hours up for test runs every 2 or 3 mths .......... Might in the fullness of time pull it out and replace with a vent, then be able to drop it off at an AC shop for them to look at and decide if worth fixing ............ Something to contemplate ....... The kitchen at Canberra Park is Air Conditioned .......................
1,874
Ian, as you probably have realised by now, if the compressor starts up and runs (as you have tested?), and is compressing properly, then it is probably lack of gas (refrigerant)! Could be a gas leak in the system, but that would not normally cause a capacitor to burn out unless the compressor was trying to start continuously. Have you reset the thermostat on a few different temp setting including heating? Good luck! otherwise it could be an expensive repair job!!!!
19,992
With the new capacitor the fans fire up and then drop off momentarily and you can here the compressor try to start but jut gives a click and clunk, actually sounds like its seized or something, hoping the run down the road next week might shake something, doubt repair is worth it but will get it looked at one day .... but no rush to repair it... its more me being OCD in that I like things to work, even if I don't use it I like it to work.........
  • Sad
19,992
Today by the Gwydir River it got to 36c, tad warm but nice breeze and feet in a bucket of river water kept things pleasant, river water temp is about 14c, frost bitten toes...................... the magic thing is great proof my 3 way fridge mods are very successful ............. Freezer minus 19.6c, fridge is 7.2c, thats after some beer grabs, my original insulation upgrade worked and the recent fitting of 2 x 100mm fans on the top vent replacing the 75mm jobs, they really pull the air out ................. its nice my theory is proven ........
I also picked up a new fan for inside van, its really a Sirocco knock off from BCF, looks the same just a bit noisier but $100 less I can live with that and today they both are getting a workout............
Bingara7.jpg ... our new travel mate Rosie ..........Bingara6.jpg.. why we luv it here. plus the best bakery...
19,992
If you were driving down the road during the day and came up behind Big Mal you would have been hard pressed to tell if the tail lights were working, while original led's they were rubbish, okay at night but like an old Morris tail lights in daylight, been an issue for years, well not anymore the back has been tarted up, new lights with mountings fitted, I repurposed the casing of a household Invertor that I scrapped was just the shot, old wear marks to be artfully disguised in time .......... only been on the Roundtuit list for nearly 10 years...............
IMG_20160325_135849.jpg.. old style 3 leds per light .................................. new style heaps of leds..IMG_20260219_103230.jpg
