Starcraft Starcraft 17:58-3 options & quirks. Post them here.
3,035
3,405
Yeah not a biggie. I have already worked out a mod to allow the door to stay open and the window open fully.
Reactions: skippy
3,035
3,405
@achjimmy we will wait to summer and see. At the moment its keep the door closed temperatures :) The windows over the dinette is not great to reach while table is there
Dave I found it opened about 50-60% which us okay, just will be times when I want 100% ( hence the mod) and I thought the handle for the window was down the door end so easy to reach! or are you talking the release catches?
Release catches.. Although get kids to do it like the window curtains. After the table pulled out the wall on our first day I do not like to lean any weight on it. Short arms can just reach the curtains :)
I do wonder with ours if the table is too big. It does not sit in the spot allocated for it to convert to a bed.
skippy
935
793
Butler/Perth WA
Our 20-63 is the same with the window interfering with the door @achjimmy and the way I get around this is just to drive a starpicket in the ground with a pool noodle around the picket and the door then hits the star picket. I then open the window to it full extension and then put the star picket in the ground so that it's just in front of the window. I will see if I can find a photo it might explain it better if ya not with me.
This works when when free camping but I have to come up with a better solution for when's in caravan parks.
What were you thinking in a way to resolve this issue? I would be interested to know.
See attached Photo @achjimmy
@skippy that is one nice setup with the entertainment system and table setup.
No idea what we will do we just thought door open most of the time, otherwise yes worried hit the window with the door. Although we lost the window kitchen side now at least with pop top can open those.
Reactions: skippy
3,035
3,405
Thinking of making a catch extension with wire.
Reactions: skippy
skippy
935
793
Butler/Perth WA
Just realised our 20.63 will have the same problem... Bugger...
Let's put our thinking caps on and see if we can invent a resolution...hopefully
Because our van one of the first 20-63 at first they told me it couldn't be done with the table as well but after some research all is good now. I don't really watch that much TV but when we go away I still like to watch my beloved AFL team hence the outdoor TV. The main reason is when we went away I didn't like being stuck inside watching TV when everyone else is outside.
With a bit of luck hopefully someone invents a resolution and you will be able to use your window again.
Mmmm be keen to see how you would do that.
Reactions: Patons
ok just went out for a look. Have a couple of ideas.
Bent wire to act as extension? Although not sure how good it will be as it will be connected to the U shape current one? Maybe slip around? I could make one to fit on a angle although how hard is this to remove and put back in?
Another thought was connect a tube to the rubber stopper with a rubber end to try to hold it there? with above?
Or get some something cut as a V shape on the right angle need cover it to make sure it does not mark. Run a line around it to keep it in place and use the wire as well?
Any other ideas
Colsar
701
868
Mornington Peninsula
Just putting it out there, move the door stopper closer to the door or install another retaining hook closer in and leave the original one for winter when window not used, or the extreme - change the window to a slider.
3,035
3,405
I reckon this is why the kitchen window went? These are the gas regs for a heater but will be the same rules for and gas exhaust.
And this is the offending window, looks closer than 300mm.
Reactions: TerriD
