The typical annex wall track which screws to the van to slide the front and rear annex walls onto the van allows the wall to be slide in at rights angles to the track; which is probably what we are all looking for. Although typically double flanged, Camec stock a single sided version. All in all that would result in the track mouth facing down, with the flange attached under the rubber seal. Hopefully that should alleviate the tightening on the BEF.
http://camec.com/rv-accessories-awn...mill-5-5m-0-23kg-m-100pp-bright-white-pc.html
Yes. But aluminium may well create a problem of its own. Stay tune, our new van arrives in about 3 weeks .... ill post my success or disasterThat would be the ideal profile to have the BEF's fitted.
That being said, mine are now fitted and working fine with the supplied track.
Depending on how much it annoys you, you could mix up some gel coat ...I put on the sailtrac on the outside of lid and were able to attach to the rivets with little problem, must of just fluked the length. Then wasn't real happy at how close the rivets were to the fiberglass(1 rivet at either end would rub if there was any movement of the lid) so then I removed sailtrac and placed them under rubber seal with groove pointing away from the van and was able to still do up press studs. Unfortunately I have now got holes that are filled with white silicon but I am much happier with the finish. Barney.
yes, I think I will end up doing that, even tho no one else would notice it, it will always annoy me. Never done any work with fiber glass/gelcoat, so it looks like I am about to learn a new skill.Depending on how much it annoys you, you could mix up some gel coat ...
Nice work, great pics. Does the pinch weld miss the rivet stubs when you re-install it, or are you cutting around the stubsAll finished both ends now
But the press studs - where do they go? Do I use the ones normally used for the Privacy screens, or do I need to mount new ones somewhere?
thanks
Location of press stud basesGot mine on Friday ($660 from the Dandy factory).
But no instructions.
Worked out the channel after a little trial and error and figured pop rivets instead of the 302 screws I bought for it. (Yeah I should've looked here on the forum first for the answers.)
thanks
