Got home with about 30 minutes of light left this afternoon so being impatient (And getting "pushed"
) I got the drill and bit's 'n pieces out of the shed to do a trial fit of the Jayco Bed Ends......
First trial fit after drilling the sail tracks and one side of the lid.
Sail tracks fitted to all sides.
Close up of the corners (Still need to debur the ends).
Trial fit of the canvas.
Front view.
Side view.
Unfortunately not enough light left to fit the press studs and get things tight so both ends will be finished on Friday.
Couple of simple hints for anyone else fitting them....
1. Debur the sail tracks front and back after drilling.... Helps them to sit flat against the lid and the rivet heads against the track.
2. Measure and check the length. Had to cut 20mm off each end. Front one wouldn't bend enough to sit flat. Side ones would have pushed into the seals on the corners when closed.
3. Use a new/sharp drill on slow speed and minimal pressure (Chipped a little bit of gel coating from the inside of the lid on the first hole
4. Get the wife to get the iron out prior to taking the first pics
All in all.... Very happy with the outcome and how they look.
Nice and light weight and easy to fit the canvas by oneself.
Now to get out there and try them for real!!!!
