Pulled the van out on the weekend, been meaning to clean the awning and get some of that mould off....once complete and still having the van out I thought I would start some additional mods in preparation for the lap.
Will probably create a new "How To" thread once complete and if it all works but been thinking of throwing a washing machine in the 17.56-2 for our lap, not essential I know but a nice to have especially with three young ones. Initial thread for this was created
here
First task was to see if the thing would fit, so I took the cabinet apart, removed the shelf and heaps of screws and connectors and was left with this
Next I had to work out if and how the below would fit into the above.
Measuring it all up prior to purchase and disassembly told me it "should" fit.
In the end I had to take the cupboard apart a bit more than I initially thought, only because the blind from the window above was getting in the way....but.......success it slotted in perfectly like it was meant to be there.......
Yes I know it takes up "a lot" of that cupboard but I will cut the shelf down that was in there and make up a smaller space next to it. It was mainly for my clothes anyway and I don't need to take heaps......
So next will the the plumbing which will involve cutting a couple of holes in the floor one for the cold water to get into the machine and the other will be for the waste. I believe it is better to have a 40mm pipe for this so it drains faster and doesn't clog up not sure though whether to use PVC or go with the plastic pipe? Also will tap into the cold water underneath to run the cold water in. Was thinking of putting a valve on the cold water which will sit just under the van so when we want to use the machine or park up for the day/week etc we open the valve to let the water in, just a safely thing in case water leaks etc, not sure if this is a standard thing on not on the machines in vans.....
Also going to get the bench either cut and modified or will get another one made up locally, have got the dimensions (thanks
@davemc ) will probably make the opening a little bit smaller but should work well as we will still be able to use the bench as a bench when the machine is not in use. (or even possibly when in use)
So lets see how part two goes, will provide an update when I am working through it.
