There's a HENRY in The Shed .......................... !!!!!!!
19,916
As mentioned on another thread The Jeeperific has been replaced by Henry, a 2020 PX3 Ranger XL to be precise, a poverty pack with 81,000km on the clock and its just magic to drive and work on, today is Day 6 so its been modified and bits pulled off to have a look, given a full service, new tyres and today a Tow Bar was fitted, truly a pleasure to work on, very few annoying sensors and other rubbish to cover people who can't drive ......................
It was a clean skin rig, no tow bar and the only extra a CB and a hard lid on the tub, first up was a service, the gods were smiling and I landed the specials so $200 covered it, of course it said in the book it had been serviced about 150 odd kms ago, yet the air, fuel and oil filters looked more like 15,000km ago following the earlier stamp, notice the difference and it would have been a sad affair if Id let it go longer ............ Ford says 15K km for a service, it will get 10K km and the tranny will soon get done, 150K or 200K km is just BS in the extreme, get done in a couple of weeks then every 40K, this one will get a Thermo valve changed so it won't cook.....
New rubber yesterday and I picked up a tow bar today and spent all afternoon fitting it and wiring it up, proved the brain is still functioning as even though I knew by looking underneath the bumper had to come off and be adjusted nothing in the instructions but you expect these things, really needed 2 people to do it but my mates older than me so I just had to use cunning, probably quicker anyway ........
Wiring was so easy, it would want to be for the price of the plug and play harness and being a poverty pack no annoying computer resetting rubbish ............. and it all worked first go............................
Next up is run the fridge power cable and power for the brake controller along with a short run to the box under the seat to connect up to tow plug...... Steps, Mirrors and a Scangauge are in the mail so more shed fun next week............ might even get to hook up Big Mal to see how it all sits, I hope good as I don't want to do the springs.
Henry is evolving into a magic tow rig ...........................
PS: in my service check over , I found some bugga had swapped out the spare and replaced it with a unused earlier version, dated 2012, mongrels so at the tyre change got the best mangy one fitted as a spare also someone had chewed the wheel nuts, probably used a 21mm socket when should have been 19mm, I manage dto reshape them so I could replace with new ones ............ never take anything for granted always check for your self and save a surprise....
b3305127-bd4f-4baf-ab50-2f4c5246b702.jpg .......................................................................IMG_20251025_124719.jpg
19,916
I may have said it before but this time I mean it "I am never doing anymore wiring on a vehicle ", run my van power lead to the back and wired up the electric brakes, mainly just power to the controller and then a short run to a plug under a seat, took me ages to get it to run under the dash and making a bracket for the 80a breaker for the van power ............... Now I can have a break for a few days before the side steps get here, the mirrors ended up nil stock so 2 wees till they arrive....................... then we will be ready to roll.....................................
19,916
No we won't looks like a new hitch needed or maybe springs ??????? Tug is about 15mm lower than van hitch, bugga, I knew I should have bought an adjustable job last year ............................... thats a static measure, have to get it all hooked up on concrete to get a better idea but I think it will be low, tug should be 20-25mm higher for a nice set up................... old unit no good either, beside don't want the WDH back on, too heavy......... as usual new springs more than likely needed but no lift this time around, bride has enough trouble getting in .....
19,916
Well its only money, bought a nice, new shiny Stinger hitch for the Jeep back in January, a great bit of kit but it doesn't have the height I need for this Henry, new adjustable hitch arrived, looks pretty, I can pick it up without needing a crane............. once these damn mirrors arrive we can go for a test run, my luck it will be a trip to Pedders for some standard height rear springs, I don't want anymore lift........... hope not but its on the cards...
tow kit.jpg ......................................................... tow hitch.jpg
4,395
View attachment 70104 ......................................................... View attachment 70105
Is the stinger hitch alloy? What drop does it have? I’ll buy it if it suits my Henry since going with larger tyres the van sits up now
19,916
Yep its a Stinger, only bought the thing in Jan, its the 100mm job, weighs in at 2kg and they are great full alloy ... if it fits you can buy it, if it doesn't you can still buy it.....:D .......
Its just the bar I didn't go the pin or ball ...................................... https://blackjacktrailerjacks.com.au/product/stinger/
19,916
The new Centurion Hitch is quite good to set up, Big Mal hooked on and tucked in behind quite well, will need to do a Tranny fix, swap out the Thermal Valve and sort out the stupid Tranny cooler set up on these things, a set up just like an oil cooler, bluddy stupid idea, why they can't just slot a separate cooler for trannies and eng oil is beyond me, they have a degree that must also includes a CDF delet I'm sure, not just Fords most other brands as well... why do easy and sensible when we can do complicated and stupid................... Rant over............
4,395
Thanks Ian
My standard hitch is around 110mm, I’ve been looking at their longer one do you think I could fit my stone stomper to it? Where did you buy the adjustable hitch and what financial damages did it inflict? I’m saving up for something
19,916
I bought the adjustable from the same mob as the stinger who imports them, https://blackjacktrailerjacks.com.au/product/centurion-hitches/
I did a hundred measurements to make sure I got the right one, mine I spent $325 on the 150mm unit.. if you scroll down the page , click on specifications they have detailed drawings of measurements for all three models so you can measure the van hitch height and tug, add about 25-30mm to the van height and that will give you the approx height you will need for the tug ........... To make sure mine where close, I stuck a ball into the van coupling and measured from the bottom of it and measured from the top of the shank on the tug to ground to get my levels, added 30mm to tugs so when van dropped on it was about level...
Postage is free, well you don't have to add anything to the price should I say, ordered Mon morn here on Wed arvo, so no stuffing around and they will talk to you......... comes with lockable pins as well..
4,395
I thought you had the 100mm version according to your first post on the subject, if it’s 150mm I’ll buy it (the free freight makes a difference!!!) lol
19,916
I have the 100mm version of the Stinger which was on the Jeep and which I have no need of anymore ............ For Sale
stinger 100mm.jpg............
This is the adjustable Centurion I have bought to replace it for the Ranger its the 150mm version ....... not for sale...
Centurion.jpg................................................
. And both of them together to compare....................................................................Both.jpg
4,395
View attachment 70107............
View attachment 70108................................................
. And both of them together to compare....................................................................View attachment 70109
You should have just called me it would’ve been easier
19,916
My great deal for a set of MSA mirrors for the Ranger just fell in a heap, ordered in October, then told nil stock due 5 Nov, be delivered a week alter, now get told Mid December should be here ............. Stuff that be more like January so canned the order, going for a set of Clearview Compacts.... so lost my $130 Linkt discount but too peed off to care, once they are fitted the wagon its ready to roll, Ranger doesn't have the extra window slot for the truck mirrors so not going to have them against the glass also finished wiring the van cam today .......... I really hate that stuff... must admit big smile on dial looking at a chassis again......................
Now for the email from Clearview saying nil stock ......................................... then I will spit it......
  • Sad
4,395
It’s just the jeep getting revenge for selling it
19,916
The Diffs and Transfer Case have 6 bungs in total, designed by supposedly wise and talented pencil men, actually if that was the case I wouldn't need 4 different spanners to remove them ............ Rear diff 5/16th ring, 24mm socket, TC 10mm Allen key, Front diff 3/8th square drive, 3/8th Allen key .....................
19,916
The big tow test is only a week away, if the new bluddy mirrors ever get here, Clearview use Direct Freight Express, so Melbourne to here is a week and a bit for them, this is the third parcel Ive had delivered by them, tracking is usually 10 hrs at least behind, most annoying as I ordered another item from Melb about the same size at the same time and it was here via AustPost in 4 days .............
Just did a 700km run solo in the wagon, most impressed a pleasure to drive and with 8.9l/100k very nice. Ambient 30-32c so Tranny temp as expected, 99c, far too hot for running solo with coolant in the 92-95 area, I can just imagine what the tranny temp will be with a van on the back certainly up in the 105-120c district, so next week it will get the job done and the tranny temp solo should be down in the low 80's solo and under 97c towing, a much better temp range for the oil and life of the box itself ....
The Thermo valve fitted in these boxes keeps the oil at near 100c, so even adding a cooler the valve won't allow the temp to go any lower, hook up a van and the temp justs climbs as the coolant can't pull it down as there's no movement in the temp range, mine seems to sit no lower than 97.7c at present, with the job done that will change and my tranny will last the distance for sure, that and proper change intervals .......
The Scanguage II I fitted, gave me a good view of the temps, just need to be able to get oil pressure and temp but no sensors by Ford for them so will have to go analogue set up .........
19,916
Wonders never cease, Mirrors turned up late in the arvo, tracking still had them in Brissie, they got fitted before the sun went down, actually think the MSA mirrors look better but than the Compact Clearviews but thems the breaks, the Clearviews work and were available .............. Tranny on Monday ....
