There's a HENRY in The Shed .......................... !!!!!!!
1,874
@Boots in Action , actually caught my ProStar unit in the act of emulating an MPPT unit, I knew it did just never spotted it, fridge ran all night, battery was down to 12.2 and not happy, plugged in the external panel and bugga me it worked its way up to 7.2a for a short time then dropped to 6.1a in a matter of minutes then sat around 4.7a the way it charged up the van batteries years back was always better than other PWM controllers it was always good early morniing and late arvo if panel pointed correctly other PWM woudl be dead ..... I'll have to see if I can scrounge another one for the shed ...................... By the time I had found my meter it was back down so I didn't get to see what the volts were. ............... It all works so now can forget about and let it do its thing, though I think the 10 yr old GEL might be a bit iffy.
@Drover , I always had an idea that the "Pro star" and "Morning Star" regulators were suitable for use with "house" panels as a lot of American systems use them for their off grid power systems up to 24 volts output, but can handle higher input voltages than the run of the mill solar controllers that are usually used with solar panels in Australia. Most of the cheaper PWM controllers you see around are not designed for input voltages from "house" panels and would probably have a hissy fit if confronted with around 37 volts. To my knowledge, most cheap PWM solar controllers max out at around 28 volts input to cover 24 volt systems. Unfortunately I believe it was NOT a MPPT performance but still a good PWM controller able to handle 37 volts from "home" solar panels, even though it performed outside/above standard specs. Perhaps the higher input voltage allowed higher outputs at 12 volts???
20,042
I used it in my shed to keep the boat battery charged from another house panel, the Prostar can operate with up to 60v coming down the line but then if you do the maths, if the volts is lower than whats on the plate the amps is higher, beyond my pay grade I think ............. mostly I see 36v on the feed ............ Big test for last 36 hrs and the GEL not only on its last legs, its down to one leg I reckon, happy as larry with fridge on and panel plugged in but just doesn't hold up all night, fridge kicks in at some time and it must drop below the 11.5 cut out, still okay for shopping use as a tour is way off so might have a new one by then, lithium would be nice but it would mean a new reg and with AGM beiing way cheaper then an AGM it will be...
20,042
Well Henry has now had the mods done to its Tranny, removed the coolant heat exchanger for the tranny fluid and replaced with 2 air flow coolers so now the ATF doesn't get cooked and when towing stays well below 105c, engine temp sits lower as well and have also fitted a dip stick on the tranny that can be accessed from engine bay, original is on the gearbox and about 2" from the DPF so 3rd degree burns was the norm, not anymore, probably not an issue if you do dealer servicing as they have it to be done at 200,000km, may as well just replace the box, I'll stick to my 40K km changes ............
20,042
Kings had a good deal going so The Henry now has a slimline 120ah AGM fitted in the tub and the old GEL has gone back to the shed, its okay to run a work light and things .... would have been nice to have a lithium, certainly lighter, 2 hernias later and I had this 30kg slimline in its rack, can leave the fridge running if need be and all is good in morning now ...................
20,042
With The Henry spending more time in the garage than on the road lately, like many I vehicles I imagine and while normally I was tolerant of these smart alternators now I'm seriously thinking of sorting it out, after 5 or 6 days in the garage the battery charge is way down at about 12.3 or so, bluddy Rangers turn on the parkers each time you open a damn door and if you leave the key in the ignition, even though its OFF they drain power, most stupid design and I fail to see how only charging the battery to 70 -75% is supposed to increase its life when you can dead it so easily .............. So until I sort it a lead from my solar controller in tub to starter battery quickly has it to full charge and all is hunky dory ... the house panel on fence outside garage works really well and I'm most impressed and with the 100w panel on tub lid no need for a Dc-DC Charger or any other set up that would require more $$ and stuffing around .................
The Ranger has an Invertor which is usable while engine running and I have been thinking if I disconnect it from Rangers power and hook it up to my tub battery/solar pack instead, give me anothe rsource of 240v in camp without having to run engine, not that I would anyway... Something to look into but might mean panel pulling so not that desperate.
1,874
Ian, it is not to extend the life of battery, but to reduce fuel consumption when there is no need for alternator output to be connected . The "engineers", in trying to minimize fuel consumption, believe there is no need to keep charging the battery other than replace what was used whilst starting They believe that all that is needed is to input sufficient power back into battery that will enable vehicle to start, hence the early disconnection of alternator input power. I agree, not good for getting a FULL 100% charge into battery to cover longer periods between use. But that's "progress" for you!!!!
20,042
Reduce fuel consumption is part of the reason but the good book says to help extend battery life as well, just like the variable vane oil pump and sundry other BS ideas all in the name of fuel savings yet the dumbo's don't do the obvious which is to fit FWH's so we have 2 axles and a drive shaft turning away, which does use a bit of fuel as I have fitted them to other vehicles and the fuel burn does drop ... Does mean you have to get out of vehicle and turn a knob. no push button so does mean you need a brain.... Just have to get Forscan sorted and turn the damn thing off or turn headlights on and it pushes a full charge......
Main reason is also when its parked up for days camping, your opening the doors and doing stuff with engine shut down and the damn thing chews up the battery power .....
Mind you Rangers had a good rep for destroying batteries in short order for awhile there ...
  • Wow
4,413
Well Ian I just did the sums, Singapore air to Da Nang Vietnam $1500 return,60 days in a hi rise beach side apartment $1500 for 60 days, probably cheaper than bundaberg to Bowen to Alice springs to Ceduna to Bundaberg, really disappointed because I absolutely love the Australian outback but I don’t want to sit at home either!!!
20,042
I thought it would be something like that .. Tempting for sure.............. We will probably bite the bullet and roll on a scaled down trip but since we don't make firm plans the tour is always open ended............
4,413
Yeah we’ll probably do the same, age is the main consideration putting back big trips is a bit of a worry we don’t know how long we can continue touring!! Might just hang around western Queensland for a month or two who knows
20,042
Go to daughters for a week and see how things are going might end up at Texas for a week, sit and think then see whats what ... thats a 1000km round trip so might be enough card shock for the old wallet ... Was thinking of Boondooma Homestead but a big shindig there last week of April but still an option if on way home from Texas.....................
Want to give the Henry a good run since I've done a few mods to it and Big Mal since last trip .............. My Jerry Can racks are getting a security upgrade to make it a little bit harder to get at them...
408
That's a consideration, was talking to a friend today and they are thinking the same, as do we...time is running out. Their next trip will be to the camel races at Boulia in July unless diesel fuel becomes scarce.
We have decided to put off our trip out West too and stay close...as much as I hate paying for a piece of grass to park on, we are going to do a few days after school holidays end at Cania Gorge near Monto, apparently is quite picturesque, being the eastern most point of Carnarvon Gorge. The bride likes walking...apparently there are some nice walking trails there which should at least keep her amused for a few days...
Reactions: DRW and Drover
7,486
Cania Gorge is a great place. We stopped at the park right at the entrance rather than the Big4 at the top. The walking trails start just out side the CP so easy access instead of having to drive back down. It had only just opened when we were there and has since been “ upgraded” but I believe it is still a good park. You will enjoy it there.
20,042
Always wanted to get to Cania Gorge but never made it, now The Bride can't do the walks anymore so the opportunity now lost, so don't waste time procrastinating just do it I reckon ............................... Somehow we have wandered over to a vehicle thread maybe we should wander back to here https://expandasdownunder.com/threads/trip-planning-during-fuel-crisis.13377/#post-217434
unless you want to talk about my fabulous Ford Ranger............
408
Thanks chartrock...I had planned to stay at the "Cania Gorge Tourist Retreat" ...don't know whether that is where you stayed. They are a bit dearer than the Big4 or Breeze ...but figure it might be a bit quieter due to the cost and no Jumping Castles or pedal go-carts...should be able to find a quiet corner somewhere to set up...
20,042
At long last I managed to get my laptop to find the ELM327 bluetooth dongle plugged into the Ranger OBD port so I could use Forscan to shut down the stupid smart charging system, while I could use my solar power set up to charge the starter battery it was really not KiSS as I would have to disconnect aux battery and plug into the starter, too much stuffing around even though both have anderson plugs, once the laptop decided to play the game it was easy to adjust the charging from 75% to 95% and to actually set the battery specs in the BCM as well, so all should work nicely and no need to worry about a flat battery if I open and close the doors a few times before driving, should be able to sit in the Docs car park without the radio shutting down after 10mins as it goes into power save mode ............
Now once the bride gets over this lurgy she found we might be able to get away......................
848
I just received my A30M OBD device from XTool. The GWM is so complicated with all its electronic control systems I thought an advanced tool might be the go when away from major centres. Still uses a phone app but can read individual engine sensors, do some service functions (like force a dpf burn), and turn stuff on/off.
Also hoping to get away in August - maybe do a slow trip to Broome...
20,042
I have found that the Scangauge II I fitted is brilliant for day to day monitoring of things that I want to know with actual read outs, I have coolant, tranny, exhaust temps on display to monitor, I can easily check other read outs if need be and do codes, its small and doesn't block out the sun ........................ Forscan is about the only system that will work the whole Ford system like the dealers can, now I have modified the original parameters I hope I never have to use it again as that will mean its hit the fan ...
Over the years I have found having to use a phone for these sorts of things is just a pain, having the info on display when I turn the key without mucking about with phones and stuff is the only way to go.... KiSS all the way.
20,042
Went for a nice long drive, Henry been in garage for a few days and battery instead of being down around 12.4v or less after a few door openings , it was at 12.6v so still good, a nice long drive and when parked in garage volts were 12.8v instead of 12.4v so sorting out the smart alternator BS has worked, once battery had settled after the drive it was showing 12.7v, battery will now not be getting a bashing after sitting idle for a few days and starting at 12.2v or something ............... the effort was worth it and didn't cost me a cent really though I have now decided to manage the Forscan better so have got a cable for the laptop instead of the blutooth dongle which was a bit old to provide all functions (15yrs old or something)
