Yes I haven't tried it yet but it does look just as you said the frame tilts downwards as you turn the tab at the rear of the vanDoes the whole frame hinge down at the rear. I see what appears to a winder tab poking out on the right hand side?
Mods done !
Extra battery ,inverter , inverter outlet ,solar panels , water filter, fridge switch and mounted remote holders .
Mods done !
i bought some mounts off ebay and some y connectors also from ebay . ill post pics later today .Batteries connected or isolated?, and how did you mount and connect the extra solar panels.
thanks moto and your right im realy looking forward to getting away .C'mon @mfexpanda , no photos, then didn't happen
The van looks amazing too mate, a couple of trips away and there will be no missing the expanda me thinks.
so ...... you run a 6 inch lead from your inverter plug to the vans input GPO. Awesome idea.
Both new cables connecting the two new panels then connected to the existing panel wires.so ...... you run a 6 inch lead from your inverter plug to the vans input GPO. Awesome idea.
It looks like your two DC batteries are permanently connected together. With the additional roof panels, did you splice into the existing cabling or run additional cables.
Hello Mfexpanda
hi @yabbietol the engel is showing room temp and fridge temp.Hello Mfexpanda
A simple question I notice in your first pic you have an Engle digital temp gauge which gave both fridge and freezer temp. Have you wired this to the van fridge and if so how? If it is connected to your Engle don't worry.
Thanks that explained it nicelyhi @yabbietol the engel is showing room temp and fridge temp.
its wireless and the other module is in our van fridge
No problem @dagree we like helping others spend their money !Thanks @mfexpanda and @yabbietol .... Mrs Dagree just saw the fridge thermometer and has just "told" me WE need one of those![]()
Nothing on fleabay apart from the companion brand (Exact copy) but I according to her it has to be the black and red engel one as it matches the TPS 1230 Solar Regulator Panel
So off to an engel dealer I will go during the week!!!!
