Cruza Drivers OUTBACK EXPANDA 16.49-3 Trips and Mods
cruza driver
Hercules
6,551
4,450
Mighty Victoria
Looks good I guess the bulging foam could just be seen as a bit of protection from legs hitting the side when getting into bed. :)!!!
True :smile: I never thought of that
I love our foam matress with egg shell and sheepskin cover. I find it way more comfortable than our bed at home even.
I hope this will be the same for you CD.
Nice work Brad!:)
Now just to get away and test it out !!
And not a big Expanda altering mod but an important one for us :thumb:
cruza driver
Hercules
6,551
4,450
Mighty Victoria
cruza driver
Hercules
6,551
4,450
Mighty Victoria
Today I had a chance to replace the wheel bearings on the Expanda after having had it for couple of years since new. I have already repacked them once in this time though and check them regularly as part of general maintenance.
The site manager came with me down to the bearing wholesalers to pick up the new bearings, seals and grease but she rode in the back of the BT 8-)
I removed one side and knocked out the old seal and bearing cups to get the part numbers requiered for the job. I used a drift and a good hammer with a bit of weight behind it to make the job easier.
The new bearings are Made in Japan which is what I wanted and were the same as the ones that came out.
You can see the OE hub seal had started to wear the lip so my timing was just right :)
When knocking in the new cups you shouldn't hit directly on them as they will likely get damaged. Also you have to hit them in nice and square and make sure they are hit in home which you can tell by the sound changing of the strikes.
I use the old cups by grinding the outer edge off with a stone wheel on a bench grinder so the old cup will fall ino the hub as you dont want it stick in the hub with the new one. Also make sure you don't put the new cups in backwards ;) Clean the old cup before using it too.
Outer bearing cup refitted, note how clean the inside of the hub is,I used carby cleaner for this.
The next part is the messy bit so no pics but fill the new bearings with new clean grease making sure the grease is all around the rollers by tapping the bearing into a dollap of grease in the palm of your hand. There is tools you can use to but I have always used this method.
I then fill the void in the hub with new grease and refit the hub seal carefully so it doesn't get dented,damaged and distorted. The outer face of the hub seal should be flush with the edge of the hub.
Next refit the hub assemby making sure the brake magnet is still located and refit your cleaned washer and nut before adusting the new bearings. Spin the bearings over to dispearse the grease in the bearings.
This pic is just an eg as I had already done it,thats why the split pin is in :encouragement:
I also readjusted the brakes whilst it was on the Jack Stands not just on the Jack
THIS IS A GUIDE ONLY AND IF YOU ARE UNSURE ON WHAT TO DO SEEK AN EXPERIENCED TRADESMAN THIS JOB DOES REQUIRE MECHANICAL KNOWLEDGE AND INVOLVES THE BRAKING SYSTEM.
SO UNDERTAKE ANYWORK AT YOUR OWN RISK
cruza driver
Hercules
6,551
4,450
Mighty Victoria
I was thinking around the 20k mark Rohan, but I haven't worked it out exact but it would be around that.
I've checked them a few times in that time too with one repack early on so I knew they were right :whistle: from delivery
cruza driver
Hercules
6,551
4,450
Mighty Victoria
Well done sir, nice write up!
Thanks Millsy :thumb:
how did you get that hub seal out without damaging it?
Since I was replacing the bearings I hit the inner bearing out from the inside of the hub. This "can" be done for repacking but you have to be ''very'' careful when doing this to not damage the bearing and I would replace the hub seal when doing this. A socket that sits on the inner face of the bearing with an extension is the go if attempting this :)
If I was repacking though I would get the seal out without hitting on the bearing at all ;)
Wheel bearings aside, you're dog is the best looking dog I've ever seen, she's beautiful!
Thanks Lara, alot of people comment on her when were out and about with her too. She loves coming away with us.
Reactions: bigman0510
shiraz
140
154
sellicks hill s.a
cruza driver
we replaced ours before Victorian alps trip Cost $326 including brake clean/adjust.took it in to be done.
next trip in 3wks to mt barker W.A. ANY GOOD OFF RD CAMP SITES.
cruza driver
Hercules
6,551
4,450
Mighty Victoria
Sorry cant help you with any camps in WA Shiraz i haven't been over that way only in a plane sorry but its on the list trust me ;)
Good to know the bearings are done too its a piece of mind job
Expanda14
90
16
Hi Cruza
just seen your in the yarra valley.
Just been looking at house,s in yarra glen
were just a bit concerned about the drive from there to our factory in thomastown each day.....
love the location mmmmm big decision
cruza driver
Hercules
6,551
4,450
Mighty Victoria
Best way there is over Christmas Hills through Wattle Glen and through Diamond Creek onto the Ring Road
Not a bad drive watch for roos over the top and Yarra Glen is a beautiful spot plenty of travel options from there 8-)
There is a forum member on here from there too and i also have a mate there.
Expanda14
90
16
Yeh know the road well as we live in Hurstbridge and take our boat up to Eildon a fair bit
just the commute each day to work will have to do it a few mornings see how it goes
