Wow... That's a lot of panels to just get to that center console.
looks good though :thumb:
You mean less clips? Gotta be happy with more screws. It is so easy to break a clip or two.Not wrong Brad but one thing I noticed is a lot of it is also screwed together
Yes @Stone Stomper value for money I'm very pleased they dont reflect back off signs like the hellas on the Cruiser on country roads.Hey CD are you happy with the Narva spot lights, there the ones I'm looking at too.
Christian
Thanks Millsy
I haven't done many k's yet so can't really comment, I presume you got the H/D springs for winch and steel bar with foam cells? (without looking at your thread)
Yes @Brad both clipped and screwed just need to make sure you don't try to remove a panel when its screwed not clippedYou mean less clips? Gotta be happy with more screws. It is so easy to break a clip or two.
Cheers @crackacoldieThe UHF antenna should hold up well, I have the elevated feed style on the Ranger and broke 2 of the fibreglass tops on the corrogations up north, that thicker style fibreglass should absorb the shock better.
Thanks mate :thumb:Looking great @cruza driver !!!
You are certainly getting some usage out of it.
What type of shocks are they? I read from the picture they are a foam cell?
I was going to go with some pedders as I have had good experience with them in the past but the tough dogs look good!
HAHA @Millsy I thought you might notice that and its handy if you forget your stubby holder :whistle:Yeah mate HD springs and foam cells.
I see your BT stubby holder has been allocated the same job as mine!!
:yo: @relgateLooking real good CD
I had the option of a rear vision mirror monitor but the GT BT's have an auto dimming mirror which I quite like and wanted to keep. Power for he camera is sourced from the reverse wiring in the factory trailer plug as you can't tap into the reverse wiring directly without wiring up a relay. The computer doesn't like that.
Thanks for the tip @Stone Stomper, I'll do that :thumb:Looks good CD, when we put Dad's in in his Navara we found pointing the camera down slightly so there was less sky gave less darkness on the landscape because the sky is over exposing the camera.
No I don't think so @Brad not at this stage.Nice CD.
Is there any intention to use the monitor for a caravan camera also?
Your probably right @maccayak plus there is no way a blown BCM would be good.I have wired my camera using a tapping from the reverse lights as the trigger to bring up reverse on the screen. I thought I read in Millsy's post that he was of the opinion the reverse output came from a relay and not the BCM. I would hate to stuff up the bcm.
Regards Geoff
