Fantastic news @Smirke
Just remember if you do reverse the van in low range make sure its "only" in a straight line as it will damage your transfer case when turning. This is because the front and rear wheels turn in a different arc which puts undue pressure on the transfer case gears. And the same when going forward again too.
If its a loose surface like gravel or grass it should be fine though. Just don't do it on bitumen or concrete.
:encouragement:
