21.63.1 mods and features
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
mornington peninsula victoria
www.bifolds.co
only 100 ah standard battery. at night with 1 tv running and media system running, 2 lights, i am drawing 4 amps. the outside combo fridge freezer uses 6 amps, but only when running, so not all the time. the tv has a backlight control function, which at night i turn the backlight down compared to the day. this saves 7 amps just by turning the backlight down. i have tested the tv and everything running with no mains or solar, and i get 30+ hours running in eco mode. however when i tested the system today, i was running everything all at once at full brightness. fridge running as well. which at night i would not be doing.
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
www.bifolds.co
i am looking at lion batterys, but i will wait to see how this setup runs this long weekend. if i need more battery power i will replace the lead acid with 3 x lion 100 am batterys. which will increase the capacity to 300 amps compared to 80amps which is all you can use from a lead acid battery.
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
www.bifolds.co
yeah i was thinking the same about it, during the day, the power is just wasted and not stored. the lions are also just so much lighter than the lead acid but you pay for it in the cost of them. same for my panels, i use 1.5 kilo flexable panels for the roof, more expensive, but very light weight.
Hi Adam, that's pretty impressive! Did I read right, 16kg for 8x 85w panels...And when you say lead acid do you mean gel or agm?
I guess the real test will be after a few overcast days. What sort of regulator/ charger are you using to cope with the amp input? Sorry for all the questions :)
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
www.bifolds.co
questions are good, yes its around 15 kg for all the panels. very light weight. lead acid/gel or agm. all are the same weight. all only good for 80% of there rated 100amp hour. they just perform better of road for some types and last longer when running down to 20% all of the time. lion batteries will give you 100 amps of useage. also they will stay over 13 volts until dead flat. unlike normal batterys which will slowly drop in voltage as they loose there amps. lion battery is 8kg instead of 30-40kg. lion will last 10+ years compared to the few of lead based batterys. the solar charger is rated at 30 amps, here is a link on ebay for one http://www.ebay.com.au/itm/SOLAR-RE...Caravan_Parts_Accessories&hash=item53e6adabee
navmatt
144
202
51
Ayr/Glenden Nth Qld
If you are in the market for a solar regulator @Burnsy go for a MPPT controller, more Amps out of your solar system than with the standard PWM modules.
navmatt
144
202
51
Ayr/Glenden Nth Qld
Not sure the quality of the tracer units, should be ok. Have a look at batteryvalue.com.au this guy knows his stuff and quality gear. He helped me setup our beach house as an off grid system.
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
www.bifolds.co
here is a picture of the roof, note the 2 x air cons instead of one as well.
Reactions: Dean81 and skippy
skippy
935
793
Butler/Perth WA
OMG its the space shuttle ready for launch! :D
I am very jealous and it looks like a neat job up there with the wiring too Adam:thumb:
But one question for you @adam 18.57.9 are you getting the 29amps though the factory wiring or have you upgraded the Jayco wiring to the batteries?
Skip
