Hi
@Gadgets 21.63.1 . We are going a box like you at the front to house our engel one side and bbq on the other. Do you see the need to add "feet" under your fridge side to give it support?
Also, I noticed your box is the width of the van. Do you find it interferes with reversing into bays? (Also what depth did you make yours). Sorry for all the questions, but we are starting to draw up what we want before taking it to be made.
By the way, love your mods . especially the entertainment for the kids.
Thanks, I designed the box myself, it was on my older van with a standard drawbar. its now on a extended drawbar. The box never even comes close to the car while reversing. i have had some very tight reversing turning corners to make over the years as well. the fridge is mounted on a 160 kg rated fridge slide. the fridge we use is a combo fridge one side freezer other side. had it full of drinks and frozen food and the slide handles it well. I had modified the slide to make it come out further than designed. the size of the box is as follows:
660 mm Deep - from Front to Back
620 mm High - From Bottom to the Top
2300 mm Wide - Including the end doors.
section a: 820mm internal deep, this houses weber, generator, 20 ltr fuel, fashing line, foxtel stand and some hard pipes for waste.
section b: 960mm houses fridge freezer combo. this also has a large fan between the caravan and the box for venting, this turns on via a micro switch when the door is closed. there is a large vent at the other end with a filter for air inlet. then a fan speed controller which enables you to run the fan at low speeds at night if you wish and fast when its connected to the car. this also turns a light on when the door is opened so you can see the fridge at night for mixing drinks!!
posting pictures in a moment for you
