thanks @Holden_man thats good advice about insurance . lets hope they get the money quick and it hasnt put them off caravaning forever and the fault is found so it wont happen again
Well... guess I'll have Mr W moving our detector tonight!!!! Thank you for the warning :thumb:the problem with a Gas / Co detector is it needs to be fitted at floor level close to the Gas source........
on the roof is no good....
damn happy they are ok, I hope Mum is not too baddly shaken up mate
Is it safe to install the detector near gas appliances? (I know it would defeat the purpose otherwise but I am thinking would the electrical in the detector itself could trigger an explosion if there is a Gas leak)?
(Sorry if this sounds like a silly question) :baby:
Mine came in the post this am, now need to go to van storage site and work out where the best place is to install it, low down, near stove and 12 v power so it won't get kicked or knocked.I'll be getting one of those
The forum should have done a bulk buy???
Whilst we all are in the quest to install Gas Detectors I do have a question for the experts here....
I went looking for the RVD devices assuming it was industry thing like the RCD and it turns out theres only the one, invented by Safelec. I came across a very long winded technical debate about the RVD merits on Grey Nomads Forum. If you want a brain bleed with the number of technical big words and concepts that make no sense to normal folk, along with the reasons why this thing is both the saviour of the modern world, and the prophet of doom ... click the link. Dont say I didn't warn you.Brought mine here, just check the amp rating on your RCD (mine was 16 but someone on here did have a 20) and then choose that size in the RCBO box.
http://www.safelec.com.au/store/p43/RCD/RVD-EMR.html
Doing it now, after you've ordered, would really show how much we all mean to you.Thought about that after I ordered!
Does it have to match the RCD thats already in the vanBrought mine here, just check the amp rating on your RCD (mine was 16 but someone on here did have a 20) and then choose that size in the RCBO box.
Well, it's official, the caravan has been written off as not repairable. The parents head off on the trip back to Qld tomorrow.
The van is being trucked to Adelaide for investigation into cause of the explosion by the insurance and SA Gov. Inspectors.
Some learnings from insurance....
If I can, I would like to say how great the Insurer RACQ have been. I have done all the dealings with RACQ to save mum and dad worrying about it, and they have been great. They assessed via the photos and mum and dad should have the money in the account within days. Unreal.
Dad set his value of insurance which has worked out ok, with them only slightly out of pocket. RACQ advised a lot of people under insure their vans, in dads case he would get the insured value or market value, which ever is lower. So the trap here is if you set the value to low, under the market value, that's what you get.
I will be putting a little more thought into insurance for the Panda. Dad added ESC to the van, but didn't itemise it, so it doesn't get included. Make sure every addition to the van gets itemised as it helps lift the market value at assessment time and then in a total loss situation you can get some money for those additions.
Jas
WHERE TO INSTALL GAS DETECTORS
This detector is UL® listed for installation in recreational
vehicles. Install this detector near sources of a potential
gas leak. Some potential sources are a furnace, water
heater, stove or oven. If potential sources of a gas leak are
in separated areas, MTI recommends installing a detector
in each area.
CAUTION: Propane is heavier than air. For propane gas
detection, install this detector no more then 20 inches off
the floor.
jas
I suppose its like putting a larger fuse in your car, you may be alright but it may burn to the ground as well, so I put the same size back in.Does it have to match the RCD thats already in the van
Yeah. Wondering what you were referring to with checking against whats already installed.I suppose its like putting a larger fuse in your car, you may be alright but it may burn to the ground as well, so I put the same size back in.
Also you have a 15amp inlet on the van so why would you put a smaller 10amp circuit breaker in?
If that's what your asking??
I bought this same gas detector for my van as well it is a great unit.Hi Holden Man,
Sorry to hear about what happened to your folks and thank god they are ok with just minor burns as it could have been lot worst. Hope they have speedy recovery and get back on the road as soon as possible.
It is better to be safe than sorry. When we bought our panda, one of the first things we did was to install a GAS/CO/LPG detector. I purchased it from ebay and the supplier is in UK. Refer below for the site:
It is a 12V unit and needs to be installed and tested. I have it in front of the Fridge and literally an inch above the floor as the CO is heavier than Air. It also has the capability of detecting LGP Gas. So IMO it is well rounded unit.
http://www.ebay.com.au/itm/GAS-CO-L...200?pt=LH_DefaultDomain_3&hash=item2c9ceb0dc0
Hope this helps. Happy and safe camping!
Ditto!I bought this same gas detector for my van as well it is a great unit.
Hard wired to 12v so plenty of battery life.
