Weber Baby Q
AddItUp
127
26
58
Hi
We just purchased a Weber Baby Q for our caravaning adventures. We have never had a Weber before, so any tips or suggestions would be most appreciated.
Do we need to do anything before the first use?
What's the best way to clean it?
Thanks.
Kenshi123
745
990
Ballarat
Best way to clean it is to get it piping hot then just use a BBQ brush and water. Cleans up very well. I think that there is a weber brand brush that you can buy but we just use a $3 bunnings one. Does the trick.
The weber cooks the best steak I have ever had. Great for oysters too.
Reactions: AddItUp
Xpandafan
Seriously Likeable!
Aug 24, 2012
1,711
648
Kealba, Victoria
As above. And follow the Weber directions for a start (re foil, trivet, etc) before you start experimenting.
Love my BabyQ so much I bought the company a FamilyQ for home as well.
BabyQ now lives in van and I'm building-in the FamilyQ at the moment with a bench, etc. and the s/steel cupboard I kept from my previous BBQ that went out in the hard rubbish collection.:)
Reactions: AddItUp
Capt. Gadget
Dec 1, 2011
1,894
1,843
Busselton W.A.
bbmwa.com.au
Would have to agree there Kenshi I cant seem to replicate how well or how fast a steak cooks on the Weber on any other cooking apparatus .
A quick wipe with a brush and paper towel while still warm and then every 6 months or so it gets a birthday on the back lawn with some oven cleaner and the hose
Bmhdg76
769
516
North Lakes, Qld.
Oven cleaner? Is it ok to use on these? Mine really needs a good clean but was a bit hesitant. If it is okay, I will use the oven cleaner then hit it with the Karcher!
BJ
boots33
708
679
Yep to clean we use the weber triangle brush, just dip it in water and scrub the plate while it is hot. For major cleans we use the Karcher also, brings it up nice and fat free. I usally wrap the burner in tin foil first to stop any stray water getting in and avoid spraying on the igniter.
Capt. Gadget
Dec 1, 2011
1,894
1,843
Busselton W.A.
bbmwa.com.au
BJ
Hi BJ I should have added don't spray oven cleaner on to the outside enamel coating it takes the shine off mine is now a matt finish
17triton
3,717
5,438
Ballarat
I shout mine to birthday when it gets filthy with a trip in the car to the carwash and make a mess there. I grab a cheap can of degreaser let it soak in then hit it off. I remove the gas burner before I start ,comes out easy.
Reactions: AddItUp
Oct 21, 2012
45
9
Hi I just use the BBQ wipes sellys brand I think, just remove grill and wipe housing out just before packing up takes about a min comes up pretty good
Reactions: AddItUp
When I give ours the gernie treatment I take out the burner (1 screw holds it in) and remove the battery push button ignition. I then re assemble and spark it up to dry out!
AddItUp
127
26
58
Thanks @Burnsy I'll check out our construction and assess the likelihood of me getting it back together. ;)
