yes true but it is hard to drive at that speed some timesDrive at 80 or your insurance won't cover you in the event of an accident and speed was found to be a contributory factor
That`s the thing you are just as likely to cause an accident at 80kph because everyone get p!ssed off waiting behind you and make dangerous overtaking manouvers.yes true but it is hard to drive at that speed some times
I see ya checked your tyre pressures and there all spot on hey.Has any one used a sway breaker bar i am having trouble with our 20/63-1 swaying behind our 2013 awd diesel territory when over 90kms was after any thoughts on them and how do they fit we use a wdh and do they work ?
hi skippy car only 10.000 kms so i recon they be okI see ya checked your tyre pressures and there all spot on hey.
Alright this might be a long shot but it might be a cause too.
I know that though work we are always replacing the rear lower control arm bushes and the centre diff bush on the rear of the Ford Territory's and BA/BF. Now if your pushing your car to the towing limits maybe these bushes are worn out and if there is two much play this will cause the car to start the swaying action.
It's properly alright when driving the car around town with slight bit of play. But with the extra load on the bushes it will dramatically increases the amount of play in the worn out bushes and before you know it there is a huge amount of play and then it's starts to cause the start of the swaying action.
Hi Adam.i have the 21.63.1, and tow it behind the 200 landcruiser. max ball weight on the van is 190kg. the van weighs in a 3192kg. at 80km and above it is all over the road. when i bring the towball up to 270kg...it drives perfect. but i am over the max ball weight of 190kg. which seems a little light for a van of this weight. i now have the friction ani swaybar on the van - and reduced the ball weight back to the legal limit. and it is perfect at any speed. i have also requested jayco to change the plate so that i can tow more on the max ball loading. still waiting for a reply thou from them. at the back of the van i have 2 spare tyres - 1 for the cruiser and the van tyre, foxtel dish as well. i also have a second air con at the very back. so the ball weight is back to normal. as the front i have a generator and other heavy stuff that will not fit in the back. oh, yes i did have my weight increased at the factory when i ordered this van to 650 kg payload. i also had an extra h frame and cables ready for the second air con at the rear. and a heap of extra stuff. so all that was included in the van empty weight.
Hi Adam we have 20/63-1 was wondering how to go about getting ball weight changed on ours it reads 147 kg empty and loaded is only 175 kg witch to me is no were a nuff van is 2045 empty buy plate and over bridge loaded is 2460 kgi have the 21.63.1, and tow it behind the 200 landcruiser. max ball weight on the van is 190kg. the van weighs in a 3192kg. at 80km and above it is all over the road. when i bring the towball up to 270kg...it drives perfect. but i am over the max ball weight of 190kg. which seems a little light for a van of this weight. i now have the friction ani swaybar on the van - and reduced the ball weight back to the legal limit. and it is perfect at any speed. i have also requested jayco to change the plate so that i can tow more on the max ball loading. still waiting for a reply thou from them. at the back of the van i have 2 spare tyres - 1 for the cruiser and the van tyre, foxtel dish as well. i also have a second air con at the very back. so the ball weight is back to normal. as the front i have a generator and other heavy stuff that will not fit in the back. oh, yes i did have my weight increased at the factory when i ordered this van to 650 kg payload. i also had an extra h frame and cables ready for the second air con at the rear. and a heap of extra stuff. so all that was included in the van empty weight.
Yeah is yours off road or standard but the ball weight is to low i reconi had to go into jayco in dandy - vic. the dealer would not do it for me. 2460 is very light loaded? we are 2490 empty. and thats plated empty. we are around 3150 loaded.
so you saying if i put more weight up front might help prob with this mod you cant put much down back any way as ours has 3 bunks its only got the one cupb what sort off weight should i be asking for on the ball ? as territory is only 250 kgits not off road. and yes the ball weight is very low.
How do i go fitting on to a haman reese wdh250 is the max on the terr, i would be up close to that, or put a sway controller hitch on it. as i have done. they are around $100 and work a treat
So you have to weld it to wdh and screw plate to draw bar ?when you purchase the sway controller, it also comes with a plate that welds to the side of the hitch. this is where the smaller tow ball fits for the sway controller. easy to fit and remove once setup.
sorry what brand you got i think i get one and try it going away for long week end so could be a good chance to try itthe plate clamps over the drawbar. and yes you have to weld the plate to the hitch, some of the new hitches now come with the plate already on it as mine did.
