RATED D SHACKLES
Fabulous
447
513
never seen colour coded shackles before, but agree, that if you need to rely on them, they should be rated.
Colsar
701
868
Mornington Peninsula
this is a rated shackle in the pic with the yellow pin, rated at one tonne ( *Try posting a bit more so your post isn't boring*) covers me for 1600 kgs. note the pin is thicker and painted.
i would not tow with non rated, a cheap one you could break with less than a few hundred kilos of the same size , used to sell em in the past life, and some of the ones from china were buggered before they even got out the door.
icetechaus
142
85
This had me curious as my van hasn't got colour coded shackles however they are marked with the Hayman Reese brand name. I found this on the QLD transport website http://www.tmr.qld.gov.au/~/media/S... and towing/Safe towing/Safe_towing_guide.pdf Pages 7 and 8 give the explanation of the rating system and it shows that the manufactures name, the shackle diameter and a load rating code are all required to work out the load rating of the shackle and not the colour.
It would seem that mine are not compliant as there is no load rating code.
ShaneT
291
308
W.A
Just incase some dont know , Bow shackles are smaller for the same weight rating.
Would Jayco sell their vans with shackles that aren't legally suited to the load?
Well just checked and none of ours have ratings or anything at all on them and we just picked the van up a couple of months ago new.
Our ATM is 2155 so I need two 2 tonne to cover 3.3tonne? Or two each over 3.3 tonne
As looking at the below "the break load limit of the shackle is rated at least 1.5 times greater than the ATM of
the trailer"
Middo
137
140
76
Got a Starcraft 16' being delivered in December so I rang Brisbane Camperland. They said that they will always supply rated shackles as per the Qld quide a tick up time.
Hubble80
524
303
Moranbah, QLD
When I picked up my 17.56-2OB it had unrated galv shackles on it. Didn't think toomuch of it until I took it back for service and warranty work. The guy helping me hitch up asked "Where did you get your shackles from?" "They were on it when I bought it" I said. "Where did you buy it from?" "Here" I said! He quickly ran and got me some new ones!!!
I have since bought some spares which I keep in the toolbag also.
Reactions: Colsar
Smergen
2,354
4,716
Bacchus Marsh
Wow... I suppose I better go check the ones on the van and see what is on them. I certainly know they aren't colour coded though, as I would recall that from hitching up.
Cheers for the heads up.
3,039
3,413
Yep you need rated shackles to be legal. But before you go getting all excited about being good. Think what the rating is on the poxy weld they do where the chains meets the aframe?
Yep I have Had a trailer part company with the car and I can tell you poxy unrated shackles hold better than poxy welds
Reactions: Matty4
Marv_mart
1,275
2,019
Saw this on the www.towingguide.com.au site
Do any of you 'Cross over' your chains and check to make sure that your chains are not too long?
Safety Chains
Safety chains are compulsory in all States and Territories of Australia. They must be strong enough to hold the trailer and prevent the drawbar from touching the ground, should the coupling fail or be accidently disconnected from the ball.
Trailers less than 2,500kgs ATM must be fitted with at least one safety chain of at least 9.5mm in diameter. Trailers over 2,500kgs ATM and up to 3,500kgs must have two safety chains. Chains must comply with AS4177-4 and have a size designation at least equal to the trailer ATM.
The chains attach the ‘A’ frame or drawbar of the trailer to the main towbar framework on the vehicle. The attachment must be made with ‘D’ shackles of equivalent strength to the chains. It is vital that the chains are attached to the main towbar framework and not to a detachable ball mount or tongue. Safety chains must be stamped with the chain’s capacity, the manufacturer’s identification and the digits 4177.
The chains should be as short as possible, leaving only enough slack to permit tight turns. If two are required they should be crisscrossed under the trailer tongue to prevent the forward end of the drawbar from hitting the ground if the coupling becomes disconnected.
Colsar
701
868
Yep Marv, do cross my chains out of habit, the cross is to catch the trailer if it falls. Always pin my catch on the ball and swing my jockey wheel towards the rear, if it ever drops won't push the trailer up and off, just bounce along. On the van I remove it altogether.
