Pics of some accessories and wiring, in no particular order. Still have to mount the second battery in the tub as well as wire the rear work/reverse LEDs.
Bullbar with UHF antenna, HID converted Narva 225s, Narva LED light bar, and LED parker/indicators
Narva Fuse box mounted under bonnet
Wiring for the overhead switches run down the A pillar
Rear LED work/reverse lamps, switched on by reverse or over ride switch
Twin Anderson plugs, one from main vehicle battery, the other from the auxillary battery.
Redarc isolator (mounted underneath Narva fuse box) This controls the 12v supply to the van for fridge and breakaway unit and also to one of the Anderson Plugs
UHF and Brake Controller, yet to work out the best mounting place for the handset yet, it currently resides beside the brake controller in a stubbie holder!
UHF control box and underdash sockets ignition switched for phone and GPS chargers.
Relays, fuse box and midi fuse holders. Wiring still needs a lil bit of tidy up, will do when all is finished. The unused midi fuse holder is for the supply to the Ctek DC-DC charger to be mounted in the tub. Wiring is run, just have to mount battery, Ctek and rear fuse box.
