Thanks.
I'm looking at the auto! Advice from some people is that it is a great towing box.
Opinions?
Opinions?
Yeah mine is an Auto so far so good the 6 speed in this one is a hundred times better than the 5 speed piece of rubbish in the last model I had nothing but trouble with that thingThanks.
Opinions?
Sorry @Rockape just saw your post I swear by my Ctek I have 2 250 Dual's one in the van and one in the tug I also have a 25AH Ctek mounted in the Van to replace the AC charging side of the Setek unit and one that I use in the shed etc great bit of gearNicely built! I have nearly finished building one that will be permanently mounted in the tub of my Ranger to complement the portable one I built at Christmas. I will be using the same CTEK. How do you find the CTEK?
Nick
Kerb weight of approx 2200 kg.
Ball weight of 200 kg.
Occupants 300 kg.
Total 2700 kg. Max GVM 3200 kg. Ok so far.
Approx Tare of van (Silverline 21.65-3) 2600 kg. ATM 2600 + 475 = 3075.
GCM 6000 kg max. 2700 + 3075 = 5775 kg.
Ok by 225 kg.
Tech savvy types, have I missed anything?
Fuel, Bullbar and anything you pack in the tray.Kerb weight of approx 2200 kg.
Occupants 300 kg.
Ok by 225 kg.
Just had a quick look on a tyre web site and going from 265/17-17 to 285/70-17 adds 30mm to the diameter of the tyre which would change the Speedo/odometer reading, I'm assuming this would reflect on the trip computer, I know mine is about 7% out according to the GPS if I'm sitting on 110 on the speedo it's reading 103 on the GPS so realistically the fuel economy is reading better than it actually is. When I changed to a larger more aggressive tyre on my PK Ranger the fuel economy average changed from 13 to 15. I think @cruza driver is in the tyre industry and may be able to add some more infoMine is only the supercab model with ally tray and full lenght toolboxes. 2"lift with steel bullbar and 285 AT tyres. The economy has been this high since new. However im hopeing it may go down when ford replace the computer next week.
@BUSH PALACE is the man in the tyre business, @cruza driver just knows a lot.. I think @cruza driver is in the tyre industry and may be able to add some more info
Thanks I think.............
