My BaseStation
Base23
467
1,089
Lots of measuring and lots of double checking and I now have 2 solar panels on the roof of the Basestation.
I had to remove the original solar panel first to get to the junction box to connect the wires for the new panel using bluepoints, I also fitted a cable gland to the box as jayco just silicon the cable in
I did not want to run the cable from one panel to the other on top of the roof so I decided to fit a junction box on the roof for the new panel and run the wiring through the roof.
First hole drilled through roof
Juncting box fitted , sika flexed and wired up
Then to drill more holes in the roof for panel mounts
Fitted the panel to the roof with sikaflex 291 and peel riverts at front brackets and sikaflex and screws in to roof beam at rear brackets
2 panel up on roof all wired and ready to go.
Now just have to wait until we get the van out of the shed in a few weeks to check it all works.
Base23
467
1,089
Fitted a reading light for my wife tonight so she can read in bed. It is a LED flexable head unit. You can select a blue light or a bright white light.
I soldered about 2 meters of twin core flex on to it so i could connect it up
I decided to mount it to the bottom of the overhead cupboard right to one side so when the light is on it will be shining from behind right on her book.
I got power from behind the factory light also mounted to the underside of the cupboard. It worked out handy that Jayco use female spade terminals to join all their wires as all I had to do was add a couple of male spade terminals and plug them together and refit the plastic cover.
Light works blue and white.
Base23
467
1,089
Started to make a mount for a jerry can holder on the front of the bastations A frame today.
I did not want to weld on to the A frame or make anything permanent as I may want to add a tool box at a later date.
Used some 150 x 50 x 3mm rhs and cut it up to make up some angle brackets
Then welded the angle brackets to some 50 x 25 rhs as a cross beam and I welded some tabs to it to bolt the jerry can holder to it. I welded some threaded nuts to the underside of the rhs to attach the lower clamps.
Then i made some angle bracket to clamp to the bottom of the A frame
I have to complete the welding and have it galvanized and all should be good.
I purchased a Jayco factory style jerry can holder so this it what it should like when finished.
pauljygrant
279
463
Another great looking mod as usual. I do have a small toolbox for light weight hoses but I could only dream of adding 20L + of weight to the towball.
Out of curiosity, what is your stated ball weight and have you checked it with scales recently?
I'm still struggling despite moving heavy items to the back and am now looking at heavier duty car springs and additional storage in the rear area when not taking the JetSki.
Yes. Agree.
I'd be interested in the weights as it looks like a heavy beast with all the additions.
You are certainly enjoying the challenges it offers.
Base23
467
1,089
Ok checked ball weights this morning and this is what I got.
loaded with water (3 tanks full) 2 full 9kg gas bottles, clothing, all equipment needed for a trip but nothing in cargo area ball weight is 335kg
All other stuff the same but front water tank water transfered to rear grey water tank (shifting 90kg of water from front to rear) and ball weight is 260 kg
All the same but grey water tank empty I have a ball weight of 310kg
This is from the thread "a bit heavy"
I did the measurments about 2 months ago.
I will check the factory ball weight on the compliance plate when i get home later.
Base23
467
1,089
Checked compliance plate and empty ball mass is 252kg
I have a trip planned over this long weekend and I will check the ball weight with the van fully loaded (including lots of stuff and 4 bikes in the back) before we leave and will let you know what it is
Base23
467
1,089
Packed the Basestation for a trip to Melrose for a this long weekend.
It is fully loaded with all water tanks full, 20 ltrs of diesel in the new jerry can/holder, firdge and all cupboards full stocked with food, drinks and all clothing, front boot full with everything and rear cargo area has 4 push bikes, webber bbq, table and 4 deck chairs and 3 plastic tubs full of stuff.
Checked ball weight and it is 305kgs
Stuff in back
Base23
467
1,089
I got a tool box for the front of the van
It is a HRD 50 ltr poly box.
I had to rotate the gas bottle mounts 180 degrees so the latches are now on the outside to give the clearance I needed to fit the box between the bottles. While I had the brackets off I welded some studs to the latches to make the lockable.
20160428_205709.jpg 20160428_211514.jpg 20160428_211540.jpg 20160428_211552.jpg
I also moved the mount for the regulator back a bit.
Before
After I moved it back
Box fits nice after doing all the mods so it could fit.
Base23
467
1,089
Looks great @Base23. How did you attach the box to the frame?
Thanks.
Have not attached it yet. I am going to use some 40 x 3mm aluminum strip and drill holes through the bottom of the box and clamp it to the mesh rack that it is sitting on.
Will post some pictures when I do it.
Reactions: Smergen
