Yes it will be very interesting, Still waiting on the 2 x shock absorbers to arrive.Very well done.. be interesting to see how it tows now.
Fitted 2 shocks tonight. I had to drill out the top shock mount holes as the new shocks use bigger diameter bolts. I also ended up painting the shocks red as black just looked to black.
Yes I was thinking the same thing about no suspension travel limiting device, Must be all good as that's how the factory Jayco air is and Airbag man have not said its needed. I may look in to it a bit more.Tragic I’d do the same
Hey so the old shocks had the Limiters to stop the springs falling out. Guess you don’t need that with airbags as fastened both ends? But I would of thought limiting your suspension travel with the bags wouldn’t have been good for em.
On my van as its sits loaded now 60-65psi = 6.5" bag height, That is recommended minimum for ride height by air bag man.Superb Brad, well down .
Is 60-65 the normal ride hide ?
So did you measure from original , how much lower it goes when completely deflated ?
This psi would change with the amount of load placed in the van.
Yes I did measure, With my van I got 80mm lower with full deflation from the factory coil spring height.
Yes Airbag man told me 90-100mm and I would say that would be on a new van with nothing in it.Thanks again mate so there 90mm from New would probably be right given your van would have settled over time ?
