My BaseStation
Base23
467
1,088
Made up the control panel wiring loom and ran compressor power supply from batteries to under van
cut hole in entertainment unit for control valve.
outside view
inside view
Made a false panel to cover wiring and air hoses that will be visible from inside cupboard, It held in place with magnetic catches.
Base23
467
1,088
Hi @Base23 do you have a part number or link to the bag kit you ordered? I have found one but says it comes with Boss bags not Firestone.
the Airbag man part number is
TA4TAJ (Jayco outback Jtech tandem air bag kit)
what part number do you have for the boss bags?
Jake
25
13
Narellan
I will get the part number and web site tomorrow when I am near the computer, will have to check the history, all I can remember is the website was something along the lines of rallie air or close to that, I didn’t pay a great deal of attention when I read what bags were supplied.
Base23
467
1,088
Thanks I will call them tomorrow, the part number is not working on there web site.
There is no information about the kit on their web site. I just called them after seeing a video of the factory jayco silverline air bag system they designed.
3,033
3,405
Looks great mate. I anguished over getting the outside entertainment unit for that exact same reason . In the end figured a waste just for the control as I never use the idiot box outside but may still do something myself as it’s a natural spot for it.
Wonder what the delay ? I thought stuff was ex stock ! Better get my order in as plan on doing it next month to the new van or otherwise she won’t be going in the shed.
Base23
467
1,088
I have been told the delay was due to waiting on the shocks to come in from one of their suppliers. Shocks were suppose to arrive to them on Friday but I don't think they arrived.
Base23
467
1,088
Made a mount for the air suspension compressor, Its made from 2mm folded plate and will be secured to the chassis using 4 x M10 nutserts. I have positioned it under the van between the axles.
Also made some label's for the control panel.
Base23
467
1,088
So after I checked out all the bits I started fitting the top bag mounts.
I had to drill a 25mm hole in the centre factory bump stop mount and then weld the Airbag man top plate to the factory spring seat.
(forgot to take photo 25mm hole but it is behind the hole in the plate.)
quick spray with cold galv, will paint black tomorrow night.
then test fit of the bags to see how it looks
Still plenty more to do but that it for now.
Base23
467
1,088
one side all done and complete. Not an easy job, cutting, grinding and welding all whilst laying on your back stuck under a van and then you need a tool or something and have to slide back out to get what you need.
Here are some install pics
all the way down
all the way up
will post some more details of install later.
3,033
3,405
Outstanding work Brad and thanks for sharing. Panel looks super professional :clap2:
What did you use for the tank drain? Any pics on compressor and tank setup ?
Base23
467
1,088
Thanks ,
Tank and tank drain not fitted yet but tank drain will be a 12v solenoid fitted in a line from the base of the tank.
The compressor is mounted to a box type frame that I made and is mounted in the centre of the van between the rear wheels.
I mounted the relay and all the wiring to the compressor frame as well so I could install it as an assembly and just plug in to the other looms I had all ready installed.
Here are some pics of the compressor set up.
compressor and wiring mounted to frame
Mounted to van (still need to tidy up wiring and air lines under van )
Base23
467
1,088
Starting to install air tank,
Made some new brackets to locate the tank up higher to the floor between the frame of the van.
Plus with the new brackets I will be able to bolt the tank to the frame instead of drilling through the floor of the van.
Cut old brackets from air tank,
Made new brackets bent from 40 x 3mm flat bar and welded to bits of old bracket
Reactions: G Daddy
Base23
467
1,088
Tank installed and plumed up.
Its held in place with 4 x M8 bolts and nuts, The tank sits higher than the water tanks so it should not get hit by anything.
(Just have a manual tank drain installed at the moment)
20180822_075609.jpg20180822_075619.jpg20180822_075624.jpg20180822_075633.jpg20180822_075648.jpg
Made all the air lines neater and secured them to the floor of the van with P clips
2018-08-22 07.55.07.jpg2018-08-22 07.54.59.jpg20180822_075518.jpg20180822_075529.jpg
False panel installed to hide all the control valve air lines and wiring
its held in place with some magnetic catches for easy removal to inspect
Control panel is all working well and very easy to use, Pressure gauge is very easy to read and to control pressures
(photo is not the best)
