Well it's about 58 days to go before we pick up our new van. I'm sure the time will go a bit quicker now. In talking to the Bundaberg dealer (comes recommended) I should get an email to sign off on the floor plan this week. Van should be ready hopefully around the first of Dec after they have done their checks and clean.
To start the ball rolling, the Tribeca needed to get a few extra wires installed.
The Van Options.
maybe we do need a TV?
Hot water in the end does not interest me either now. for the expensive - extra weight of unit, and from what I can tell the hot water runs out pretty quick as does water in tanks.....camping for me is partly about going to a CV park to spend looong hot showers - really steam it up.
I'm paying the same - why would I want to clean my own shower...bad enough at home - for my wife
Solar will be down the track when I know a bit more about, caravanning, free camping and our power needs.
- Fridge wire (6B&S) from Car battery to the back. Not anderson for now (12pin) but keen to change over once I get the van. Still not sure why I just did not install anderson strange up. But I haven't. From what I understand the van will only have 8 B&S...so I guess I may upgrade that when doing anderson.
- Power cable 6mm both positive and negative from battery to the back
- Both cables above are connect via a VSR which cuts the power to the wires when the start battery voltage drops to low - got it for $38...pretty happy with that as I did see for $80.
- Brake controller - I installed Redarc towpro. I'm pretty happy with the small profile and does not intrude in the cabin space. I also like the manual brake application.
- Lastly, rear view camera. I have a factory one on the back of the car which nicely shows me the tow ball when reversing. I installed a new 7"monitor to the right side of the driver (beside door) to install a camera on the back of the van. The monitor is suction mounted to the dash which works well so far - have not driven on any dirt roads as yet. Also 7" to me seems about right in size.
The Van Options.
- 164LTR 3 WAY FRIDGE
- ROOF MOUNTED TRUMA AVENTA A/C
- ALKO DROP JACKS
- U/SLUNG AXLE'S
- DIVIDER CURTAIN FOR MAIN BED
- ZALE / CADEL CHARCOAL / FURLO
- BED CONVERTER FOR CAFE SEATING
- Portable toilet and tent for night time use. From what I have read Big W's version has the biggest seat in its class - correct me if I'm wrong as I will purchase same day I get van
- 100mh battery
- external gas point for BBQ
- Looking at getting annex walls from australia wide annexes - they have been recommended to me.
- Pic above is of another van but the same
