Just purchased expander 21.64.1
Chris Mason
double at the rear, full size queen at the front, 2 bunks with table seat conversion for bottom bunk. slide out lounge. full size fridge with seperate freezer. draws under the front and rear beds. 3 zones audio system, seperate controls and inputs. 32" led tv in front and outside, 15 inch tv for the rear, seperate toilet and shower, washing machine in the ensuite. full size ensuite, twin air conditiners, lithion battery, 250 watt solar power on roof, full awning and annex, massive 650 payload capacity, double stacked power points everywhere, bottom point for mains power, top point for inverter power, extended draw bar, bayonet bbq connections, privacy screens.
We ordered almost the same van over 2 months ago..21.64.1 OB...delivery on the 18.11.13
Ours is pretty much the same except for our bunks are a triple, the lounge has a bed conversion and the full annex has an add a room and the porch.
We are on the gold coast and are planning a visit to the sunny coast for weekends so we may cross paths.
Chris
Reactions: blacky
7,491
:welcome:Welcome to the forum @Chris Mason , good to have another Goldie on the forum. Just over a week to go, the tension at home must be reaching critical by now. Don't forget to post up some photos when it arrives and post up some info in the member introductions.
GCMASOS
56
Not registered yet. still waiting on the annex to be fitted.
Gets done on Friday next week.
Possible delivery that day if not Monday. Will let you know.
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
mornington peninsula victoria
www.bifolds.co
we have the lc200 now to pull the thing, and long range fuel tanks fitted next week, which gives 250ltrs of fuel. that should increase the range a bit. pickup ours next thursday. weights still not in, but should be just under 2900kg fully loaded. as there is a 650 pay load capacity on this monster.
Reactions: blacky
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
www.bifolds.co
yes we have it, huge van, heaps more space and storage. weights are 2460 tare, 3195 total weight max loaded. glad we upgraded the car to tow this thing. the upgraded fridge, washing machine, second air con, extra wiring and points, would have made the difference in the tare weight. it also sits higher by 150mm than the 18.57.9 as well. so we had to replace the roller door to get the thing into the carport.
Reactions: blacky
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
www.bifolds.co
as you know, there are many items which run from the mains that we use in our caravan which has a 12 volt input. these items use there own external power supply that is rated at 12 volts. such as external hard drives, modems etc. the problem is that you still cannot use the 12 supply in your caravan on these items without destroying or making these items unreliable. connecting these items to a inverter to run the power supplies can be done without a problem, but you are using more amps to convert up to 240 volts then back down to 12 volts. the reason you cannot use these items just on the caravan battery is because, when the battery is not being charged the output voltage is around or just above 12 volts. (which is fine) BUT when the battery is being charged, the voltage will increase to over 13.5 volts sometimes to 14.4 volts and this equipment is not designed to run from this voltage so therefore is destroyed or its life if drasticly shortened, as the internal regulator is running hotter than designed to. i am now using a item from ebay which accepts 8-40 volts input and gives 12.5 volts fully regulated output.
my current draw for running, 32" led tv, modem, amplifier, 2 tb network hard drive, 8 port switch, wd media player (tv running though inverter) is down to 4-6 amps. which is fantastic. it used to be over 12 amps running all though the inverter. the other trick for saving power while still running all this is to select a tv that has panel light adjustment. so that you can adjust the power going to the panel which lights the lcd up for the tv. not many tvs do this, but the power savings can be around 6 amps when watching tv at night.
Gadgets 21.63.1
aka - adam 18.57.9
Jun 29, 2013
398
156
53
www.bifolds.co
Mike7
144
Adam can you give me more details of your 12v regulated power supply please, a link if you have one would be great.
