Yes got 2 batteries. Have no idea if it is working as it should but drifter seems OK
Mate your shots not clear enough, but if like mine your 2nd battery neg is hooked to the other side of the shunt. (Opposite to Bigmans sketch) then it's wrong I think. Yes the drifter will work (mine is) but it's readings in terms of battery usage are false.
Also note that you need to program what your battery capacity is into the drifter. It's default is 100ah I think. I bet with our setups it's still down as 100ah not 200ah?
