Well all setup for our two week stay at Mandalay Tourist and Holiday Park, Busselton :)
Only one desicion to make...... Which one first ;) 8-) :D
20,019
Oh yum,yum what a decision to make I would go Gentleman first......no,no the Glenn...no,no have to be Jack.....no The Glenn for the night and Jack to savour of a late afternoon.......................................but then again !!!!!!!!!!!.................is that enough for 2 weeks ?????
Been a while since I've done any additions to the expanda but received a late Christmas present (Reversing Camera) and spent a few hours today fitting it. Ran out of time to wire up the Prado due to visitors and finding out that someone that I will not name (Just in case Mrs Dagree sees this ;) ) threw the ali angle I was going to use on the bulk rubbish pile last weekend >:( and when removing the existing bracket found the 7 pin plug was cracked when I had the new towbar fitted so that will be a job for next weekend.
Added a bracket and drilled a few holes in the rear wheel holder and fed the cable through the chassis beams.
Bought a junction box from Jaycar, fitted the plug/socket and fitted it inside the drawbar.
OH and I had a helper LOL
Will post a pic of the screen when it's all up and running.
skippy
935
793
Butler/Perth WA
:emptiness:That a well thought out setup @dagree good idea at the front on the A frame with the wiring box too. I will be keen to see how it looks on the big screen with the camera hooked up. Any info on the camera as well.
I hope the little helper got payed to @dagree :boink:
@skippy the camera and cables were part of an Axis brand caravan and car system http://www.audioxtra.com.au/PRODUCTS/Mobile-Safety/JS055CK.asp
A work mates partner works for a supplier and he just wanted the monitor and car camera. I did him a favour and he got her to order the system and gave me the caravan components as a thankyou!
The little fella got lunch for his efforts but I have got him booked in next weekend to mow the lawns and trim some bushes while I wire up the Prado... Might even give him some dinner next when finished 8-)
Reactions: skippy
skippy
935
793
Butler/Perth WA
We have an account with those guys though work, might have to pop in and have a look around. It's defently looks the goods @dagree
Managed to get the wiring done on the Prado for the reversing camera on the weekend and had enough light to fit the bracket on the rear tonight and almost finish the install.... Just waiting for the switch to arrive (Standard fitting Prado size so no mods needed).
Once the switch is fitted it'll be time to switch :lever: on the power and see if I've done it right and try it out :tea:
On Order........
All tidied up.... 2 x Anderson Plugs, 7 Pin Trailer Plug, Air Bag Valves and camera plug all in the one area.
Hopefully get the pic of the screen for you on the weekend @skippy !
skippy
935
793
Butler/Perth WA
Hey Dagree
:eek-53:Thats a neat job on that bracket and the way you have the seven pin trailer plug/Air bag filers/camera connection all on the one bracket. :eagerness:
Here ya go @skippy ..... Nice view of the colourbond fence behind the expanda 8-)
Full screen shot but unfortunately no radio or cd can be played as it is plugged into the auxiliary setup.
Next option....... Hit the Picture in Picture button and radio and camera at the same time :encouragement:
Might have to see what the 2-Zone button does!!!!!
skippy
935
793
Butler/Perth WA
Looking good @dagree all you need now is a long weekend to try the system out:D
2,652
3,819
nice work again how many cds dose that hold ours can take 6 , original radio in it , but I do like it im having trouble where to put my screen don't like it much on the windscreen ar those radios expensive I just have to fit my camera to the van and its all done
