maybe stupid question but where is this tempering valve so I can check itIve found poor pressure to be the biggest PITA in my Panda seems every time I take it out I find something else is reducing the pressure last time it was the filters on the Tempering valve were full of crap from the bottom of the HWS as I had just had the anode replaced, over the time I've owned it Ive had a dickky tempering valve, the Pump plumbed up wrong, a sticky pressure valve, a sticky non return valve and even crap in the little aerator thingo on the end of the kitchen sink tap.
Mine is underneath the Van Its a T shaped Copper Valve usually with a coloured plastic cap on top mine is Blue, with 3 hoses connected to it 1 in straight from the HWS, 1 in from cold water and 1 out to hot side of tapsmaybe stupid question but where is this tempering valve so I can check it
are yes was looking at that today dose it need cleaning ??? are there filters in itMine is underneath the Van Its a T shaped Copper Valve usually with a coloured plastic cap on top mine is Blue, with 3 hoses connected to it 1 in straight from the HWS, 1 in from cold water and 1 out to hot side of taps
Yep little Mesh filters on the inletsare yes was looking at that today dose it need cleaning ??? are there filters in it
thanks heaps bro give it a go tomoz let you know what I find my water is crap flowing the little one way valve in the filler connection was buggered but its always been crap so looking at all issues maybe get a PLV like @Crusty181 connected to the tap do away with the van one like everyone else pump is good but mains is crapYep little Mesh filters on the inlets
Looked at a few yesterday realy im over this pop top roof and expanding bed ends but its what we have misses would realy kill me if i segested up grading so im staying quiteI'd just chuck it away and buy a new van @Bluey , much easier.........................![]()
Yes saw them but if ours ar 350 kpa cause of the hot water system is 500 then to muchHave you tried this one?
Pressure limiting valve: 'Valve Pressure Limit Nefa 500kpa' 15x15mm F Plv500fhs $69
http://www.bunnings.com.au/valve-pressure-limit-nefa-500kpa-15x15mm-f-plv500fhs_p5070005
Hey @Bluey, the HWS is rated to 850kPa, and there isn't too many domestic supplies that would be more than that. That kind of pressure would blow the kids out of the bath, through the window and you'd find them on the neighbors roofYes saw them but if ours ar 350 kpa cause of the hot water system is 500 then to much
Good workHey @Bluey, the HWS is rated to 850kPa, and there isn't too many domestic supplies that would be more than that. That kind of pressure would blow the kids out of the bath, through the window and you'd find them on the neighbors roof
Wow @Jags73 , most places would have instant water fountains on the footpath with that pressure, must be great turning on taps and having decent flow, house must have good PRV's as well. I've actually refitted mine as where I'm camped the new camp pump is giving great pressure, so much the funny flush is too much, so I thought I better refit it. First time I've found awesome pressure.
Good research @Jags73. I have one those plastic 350kPa Pope tap fittings. Seems to make more sense to fit the PRV to the tape as opposed to having well inside the caravans plumbing systemI was reading the same on my Suburban hot water service, but in the operating, installation & service manual it states that a 350 kpa mains pressure reducing valve must be fitted, 1st page
I have been doing some fast learning, I have the Reflex 350 kpa PRV which has a built in non return valve & gauze filter, I pulled it apart to clean, just preventive maintenance, & found it was a big no no as special tools are needed to pull it apart, standard spanners crush the stainless thin walled cylinder & never to work again. I grabbed a new one of ebay to get it up & working again.
While I had it apart I noticed these are full flow valves until the the 350 kpa or 50 psi is reached then they are regulating, stretching springs only increase the pressure or cutting them decreases the pressure.
My main concern here at Angle Vale I have 700 kpa or 100 psi mains pressure & tries to blow the hose of the van fitting & leaks water,
On the property I can only use Hose Link products, so for the van I found a cheap $10.00 Pope 350 kpa PRV from Bunnings that screws straight to the tap that drop the pressure for the hose to the van.
Checked the pressures on the van & I get the 370 kpa max with working pressure of 350 from the mains & 350 kpa on the 12 volt pump, but this doesn't represent flow, but I do have good flow at the taps on mains & a little less on 12 volt pump, very happy how it works & I'm a little wiser for any repair jobs in the future![]()
