Do they help with the light in the van, in the morning? I'm still finding it bright in there even with the skylight blinds
I had the new style lid replaced with the original incarnation. I wanted to fit the sail track under the lid as opposed to the outside edge, because it looks better. I searched for, and found right angled sail track which the opening faces down instead of out to avoid what others have found with the BEF being too tight when clipped to the press studs on the van.Well the BEF is on the van! And it looks pretty good actually - we have to do some adjusting to the sides where it attaches to the van, as they didn't quite put the press studs in the right place... But the best news is we can leave it on with the lid closed - we tried it last night and it closed easily
Thanks @Crusty181
So my next thought is some Velcro strips? (Not the little ones - I'm talking the wide, adhesive stuff from Spotlight). I'm not sure how the adhesive stuff would go attaching to the canvas though - might have to try and hand stitch it on perhaps..
Anyway looking for any inspirational ideas folks!![]()
This may end up to complicated to explain, but here we go. ( I did it on my 16.49.1, but it now gone. Ill try to find some pics)Thanks @Crusty181
Now we just have to devise a way to "hook" the new BEF up when we want to fold up the lid (like you do with the black privacy screen). We thought about attaching a press stud in each bottom corner of the BEF, but it won't clip up to the existing press stud in the lid due to it being too close to the new sail track - plus I think the canvas would be too heavy anyway and just unclip straight away...
So my next thought is some Velcro strips? (Not the little ones - I'm talking the wide, adhesive stuff from Spotlight). I'm not sure how the adhesive stuff would go attaching to the canvas though - might have to try and hand stitch it on perhaps.. And I'm not sure how well the adhesive strip would stick to the underside of the lid - hubby thinks the heat may affect it?
You need a hook of some description on middle inside front edge of the under side of the lid .... outside the line of the BEF. Drill a hole in the top strut bracket on each side, and run some shock cord across. Tie a small loop (6 inches or so) of shock cord in the middle of that shock cord and put a s/s key ring on it. To pack up, drape the BEF over the long shock cord, and then pull the loop and hook it onto the hook. Should be clear as mud.
Worked very well for us for 5 years on the other Expanda, and made for very simple and effective storage. You can leave it packed in and not deploy it.
You going "derrrrrrrrr", I know. Ill find some pics, you love it
Its as correct as it gets. @Flossymk1 hardlid is the new incarnation, and is very different to yours (and mine). My van arrived with the new lid, but i requested the old lid like yours be retro fitted. Your track is where Jayco fitted it to the old lidsHaving see @Flossymk1 BEF sail tracks on the underside of the lid, I'm wondering if mine where installed correctly! They are on the outside edge of the lid. Does this look correct to you guys?
.View attachment 28541
That's how I was instructed to install mine from Holiday Annexes.Having see @Flossymk1 BEF sail tracks on the underside of the lid, I'm wondering if mine where installed correctly! They are on the outside edge of the lid. Does this look correct to you guys?
If you ordered the BEF at the time of purchase apprently it should be fitted with the old lidJayco work in mysterious ways. My van came off the production line in October this year and I have and old model lid! But a van that came off the line at the start or middle of the year has new model lid? Who's on first base?
Which explains why back in June when we ordered ours we had to choose which bed end we wanted, as we couldn't have both.If you ordered the BEF at the time of purchase apprently it should be fitted with the old lid
Yep, that explains it, we ordered ours at the sometime, had no idea there was a choice, oh well.If you ordered the BEF at the time of purchase apprently it should be fitted with the old lid
