836
Well after much faffing about I decided it was time for a new tug. The Dmax is at 180,000kms, and while super reliable, is showing it's age and all the dirt roads.
So in keeping with my tendency to buy Chinese on ebay I bought this...
A demo GWM Cannon Ultra with 700kms on the clock and a factory tow bar - hopefully without the advertising - for $44k. It will need new all terrains and a canopy but that should still be not much more than a non demo model with 600 less kms
The one long range tank I could find only adds 30l so it might be jerries this time around. But the extra 100nm of torque should be very welcome.
19,973
180,000km the DMax is just run in .......................................
Interesting to see how it goes, at that price a new one every couple of years ............................................ quite a few Pensioner Utes around here so pretty popular ............................... LR tanks are an expensive bit of kit, the Colorado was all lined up for a poly tank against the headboard, more fuel and less dollars than one underneath............ not sure if they do them for tubs though....................
2.4lt with a 9 speed, slowly starting to get some legs by the sound of it and 18" wheels is good choice, I actually would think of having one, not my first choice but a realistic choice for my wallet ....................... So hook up and let us know how it goes, my wife hates digital controls, we have all sorts of fun trying to adjust things as we roll down the road ......................................
Reactions: jazzeddie1234
836
Now the joy of fitting out a new tug. Today I just faffed around going from idea to idea to some completely unrelated jobs...
The cannon towbar is quite low so the wdh will have to move up a notch and the receiver pin hole is much closer to the end for some stupid reason so the whole hitch sticks out way more. They don't publish a towball to diff max measurement like the dmax so we shall see.
Started looking at the uhf. I want to keep my current one so I have to see the unit.
Screenshot 2025-07-27 154415.pngDesigned a low profile housing that I can stick on rather than screw. The channel is for the mic cable
20250728_113059.jpg First test fit looks ok from the top and well away from my knee
20250728_113045.jpg I printed a longer section to hide the cables. Looks a bit chunky in the pic....hope it works ok. Sadly, in the facelift model, they removed the little shelf under the steering column where it sits in the dmax
What do you think? Looks ok or try harder :oops:
19,973
Looks okay, so long as knee doesn't whack it .............................. Most envious regarding the printer, I often find one would be handy but would probably frustrate me more......... Stock springs will probably be too spongy as well so I wouldn't do anything major to the WDH untill you see how the suspension goes.... mate who just replaced his old BT for another went and reset his tow hitch set up, new shank and now finds the stock suspension is pretty ordinary so is upgrading it, something he had to do with his old one and we talked about with this one but he believed the dealer talk ................
836
I have wondered about doing a trip without the wdh to see how it goes - less weight, less fiddling around. The Cannon is a bit heavier and wider. But the early towing days with the dmax still haunt me. Then again lots of people are towing without it...
And my new brake controller arrived. A curt spectrum that has a fancy rotary knob - a bit like the redarc but with lights. Looks like I can run the control cable up the same channel as the uhf mic in my new holder and stick the knob just to the left of the uhf. I wanted a brake controller that had a separate sensitivity (or boost) setting so I can set max and min brake force as my van works better with a higher start voltage. Seems to be a unique option that USA made controllers have
19,973
Ive experimented over the years with and without a WDH, on the Colorado it towed fine without BUT on the open road doing a $ into the wind, it would get under the front and lift the ute up so the steering got a bit light, full bash plates and a lift meant I was running out of extention on the front suspension so I put the WDH back on to throw some weight on the front end, otherwise fine without, while with the Grand Cherokee the Nivomax rear shocks would push the rear back to normal height but it could porpoise a bit on undulating roads, soft OE suspension rubbish but I replaced the suspension, it then rode better but I fitted the WDH just to add a bit of stability and take some of the load of the Nivomax shocks, they cost about $1500 to replace so wanted to try to keep them good, but I got fed up with the WDH, is heavy and hurts my hands so I fitted a set of Airbag Man HD units, brilliant bit of kit, better ride solo and towing by miles, coil spring rear so no worry about stuffing up a chassis, haven't got a chassis to stuff up anyway .................
I have always used Tekonsha units, I like the display and ability to see what the power adjustment is as well as the handy manual brake lever seems to have all the bells and whistles of the more expensive brands and I don;t have to drill holes or remove panels to fit it................. Its just set and forget just the way I like it....
Does the Cannon come pre wired or do you have run it yourself ???? Jeep was sort of half done .........
383
Not butting in...but I too don't use any WDH system anymore due to the huge additional weight, plus it pushed the tow ball hitch point further back...I have the Hayman Reece brake controller in my Jeep...The Quadralift in the Jeep is great, it keeps the whole show nice and level...
836
I'm getting too old for this...
20250803_121353.jpg Aliexpress $20 mudflaps...no I don't know why they are not standard
20250805_145525.jpg Curt Spectrum brake controller and UHF done. Going to miss the info on the Tekonsha but this unit is pretty clever
20250807_142053.jpgMuch crawling under the ute to run wires from the battery to the 7 pin...to the anderson...to the tub. Lower cablewill be the 25amp dcdc to the tub batteries, upper cable from the batteries to the tow bar anderson, red wire is ignition sense that I use for various jobs
20250804_113015.jpgTrying out a canopy this time around. Wife didn't like the colour matched fiberglass so a black one it is. Have to wait a few weeks for it to arrive
I'm slowly getting used to all the flashing lights and touch screens, but still can't reverse into a park using the cameras :crazy:
19,973
I know what you mean, trying to do contortions to get at stuff, Im past it ....................................... I bought ebay mud flaps for the Jeep years back, $20 and the funny thing was they had the Jeep part number on them ...
836
Did a solo hitch up yesterday and towed the van to a level spot to check the WDH settings. On the plus side the 360 cameras are awesome but the electronics sure don't help someone like me who does all sorts of shortcuts to get the ball aligned. Usually I reverse until very close, pull on the handbrake (while in reverse), hop out see it needs 20mm, hop in (leave door open), handbrake off, 20mm back using foot brake, hand brake on, hop out to check....
Nope, nope nope.... door open, alarm, no handbrake allowed when in reverse, 50mm lurch when swapping from reverse to park, 5 goes to get it right....
19,973
Ha,ha ........... I use my knee as a measure and wind the hitch up usually to a couple of inches above my knee cap so ball slips under, on the Jeep cam when hitch is under the red line its home, except those times when it bounces off the red line, then I know I stuffed up the height ... so leave wheel chocks in place until its right .........
Before cam used a mark on ground which I could see in mirror and stop when bumper lined up with it ............ usually on the money or just did it blind.
836
Decided to stick with what I trust and put the WDH on for the shakedown trip
Stock suspension is sitting ok and the extra power is just bliss from a standing start. The Dmax takes ages to get up to speed compared to this.
We've done about 1000kms down the south west towns, with 90% in the rain sadly. Fuel economy looks fairly similar around 18l/100km but need to check this when I fill up again. Brake controller took some getting used to but is working great.
Overall verdict so far. I'm happy with how it's going.
Need to change: A fill near empty is 65l compared to the dmax 110l so it will definitely need an extra tank or something - I need a minimum of 500kms of towing range up north. Probably install airbags once my Son's girlfriend (yay for a machinist in the family!) makes me some adapter plates. Lastly some A/Ts and a bash plate for the fuel filter - great for access but who decided to hang it so low!
19,973
I wouldn't add airbags unless upgrading the rear springs even with added chassis panels ... looks the goods ....
Those poly tanks that fit in the tub are a good option, no need for another mortage like the ones underneath.
836
I'm looking at poly marine tanks as they seem to come with way more variations and accessories like fuel senders and breathers, etc. The cannon has an extra large fill cover because some models have an adblue tank. It would be very neat to put the aux tank filler in there too
I won't mention the airbag kit is a $200 aliexpress special then 8-) .
4,399
I'm making the same comment, "What Have I Done " , off to the car yard today.............................................
What are you doing, I’ve had me Everest for almost 3 years now and still pine for the Jeep. There is a mob in Sydney who specialises in Jeeps. Had I known earlier I would probably have got a crated motor and gearbox fitted by then it couldn’t have cost $80k like the Everest did!!!
383
I am still reeling in shock as well when I heard the news...I like my Grand and really don't know what I'll do when it eventually gives up. I reckon I'll consider repairing this one or just buying another Jeep...
