Thanks mate. Yeah is a bit low. Oh well just wondered if there might have been a chance to sneak a bigger one in at pick up. The factory did knock us back on the 22" .Here's a pic of the tv I took yesterday. 19.5in.
Has anyone asked for the interior night lights that are in be expandas ? I did a factory tour today and the guy said they were standard on the Expanda, but not on the Starcraft. He suggested I get the dealer to put it on the order form, he also mentioned that the factory is happy to do it. It has the same wiring and all.
We have a bike rack coming on oursWith regards to the reading lamps on the main bed, our dealer confirmed that ours will be on the door side of the van as per plan that was given to us prior to sign up.
They've also confirmed that we can get the night light (as per expandas), just needs to be on the work order. I wasn't aware of the night light until yesterday when we did a tour. It's the main lights in the roof, instead of the off / on switch, it's a 3 way switch that has a dull blue led / off / bright white - looked pretty good. Might be useful with out little girl in the future.
Has anyone ordered a Starcraft with a bike rack ?
Not sure Jimmy because I don't think I've ever seen one with a standard fridge - apart from yours. From memory I've always seen a power outlet there next to the tv. But I think its what Dave was meaning by needing to run an extension cord across the new sink location to be able to run any appliances on the stove top cover when the stove is not in use - that's really the only bench space for a toaster or kettle etc.
Now, where do you guys store your external table? We've got one of those plastic types with two bench stools inside. Where should we carry this? Just on the floor, or on the bed? Don't think it will fit under the main bed haven't checked yet.
yes Jim, expect to do that, all we can do is refer to the plan at time of signing, as well as the email confirmation yesterday as well as time and date of phone calls. We're still a fair while away - hopefully they will sort it out by then.
So why would the factory put the number plate & light where it is blocked by a factory fitted bike rack ?Yep it's blocked, you'd need to move it right to the bottom of the van, which will leave a few holes.
