Sirroco Mk II fans
MDS69
735
806
Sirroco fans are great. We have 3 in our 14.4ft van :confused-87: Think we have a fan fetish
@spiderpig where do you have them mounted. I have the same size van and was thinking of putting one in each bunk and one at the main bed but was concerned that the ones in the bunks would be too noisy and push too much air with the curtains closed.
spiderpig
167
216
Canberra
We have one mounted under the last little cupboard/hatch next to the main window that opens near the table, this can then be used when your at the table or pointing into the main bed end, which is mainly what its in that spot for. Another one is mounted on top of the cupboard at the back next to the top bunk. This can point into the top bunk or be directed to the kitchen area when cooking etc or just in general to keep air moving in the van, folds down flat on top of cupboard nicely here too when roof is down. 3rd one is mounted to the wall near the little light in the lower bunk. We have no problem with it blowing curtains open etc as generally only use it on low or mid power setting.
Reactions: MDS69 and G Daddy
Macca_75
680
596
SE Suburbs, Vic.
He'll only do it once.....though maybe not if he still has another hand.
:faint:
Not my little 6 y.o. The first time will be a mistake - not every time after that.....
Trust me It doesn't hurt!
Argh my finger!!!!
I used double sided tape and two screws on the backing plate , it hasn't moved and I don't expect it to.
The blades have the softish protection bead on them.
Hmmmm - not sure if you are taking the P155 or not (looking at your middle finger nail) ;)
Has anyone tried the Jayco fans that clip to the bed support bar?- I think they are about $90?. After buying the crappy oscillating ones from Jaycar & supercheap. I can't ring myself to pay the money for the non oscillating siroccos, even though 140bucks is so cheap in comparison to the $215 I've seen at my local store
We have 2 x Jayco fans (came with the van). when comparing the Jayco unit and the Sirroco (I played with the Sirroco in the store) the Jayco are far more noise and give off way less air. You can't even compare the 2 for noise of air moved. Having said that we will keep using one of the Jayco ones for the rear bed. Each of the 2 bunks will have a Sirroco installed (after I figure out some sort of guard). The third Sirroco will point either towards the front bed or dining area (depending on time of day - it will be manually swung around). Currently thinking of mounting it behind where the TV sits OR on the edge of the slider.
Two would be ideal I think.. But We have just the one near the door View attachment 47809 this position allows us to point it either at the table- our bed- kitchen or even the bunks . It moves the air around nicely . It's no tornado but just blows an a4 sheet of paper off the table to give an idea.
The one does us most of the time but we also circulate the air through our heater (just fan no heat) when needed. We have another fan run off an inverter that we sit on the wardrobe pointed at the bunks that does oscillate to get both beds if really hot. I wanted to put another permenantly mounted but I don't think one would do both beds unless it oscillated .
So it seems mounting to the inside of the outer wall might be OK. Thanks
Reactions: Pauly
Macca_75
680
596
SE Suburbs, Vic.
What's the difference? Ours look like that but black
@mfexpanda - I thin k the pic is for Gen 1. It was more for reference for a guard than anything else. I think some of the difference I read about are
1) Made in Canada instead of China (not sure if this is good or bad o_O )
2) I think they now have 4 timer options
3) Polarity protection so they don't blow up if you wire them wrong
Definitely not worth upgrading if you already have Gen 1 fans.
Are they effective? None of my searches came up with this.
Looks good!
Like the Sirocco, the Ultimate is very impressive. It a very solid and weighty unit. The Sirocco has 3 speeds, and a timer; the ultimate has 2 speeds, no timer. The Ultimate is a bit less intrusive and easily detaches from the fixed mount. We've only used the fan on low speed, high speed nearly blows us out of the bed.
I bought 2 from a QLD guy on Ebay for $83 each. He was great to deal with, if the link below doesn't work search for user "ulublu" on Ebay
http://www.ebay.com.au/usr/ulublu
Any marine parts seller will have them such as Whitworths. Just make sure you get the package that has the cig plug, screw on mount, and suction mounts. If you fix the screw on mount, you can still use the fan elsewhere on the suction mount.
"Industry recognized and a long time favorite of sailors! The model 747 Ultimate 12 Volt DC fan is recognized by Practical Sailor magazine as a “Best Buy” in the marine market."
That's great....but I might avoid Whitworths. It costs me money every time I go near them.
I'll definitely investigate these....we have no small sticky fingers to worry about, and they seem to fit the bill. Just want something to keep the air moving when free camping but light and stowable.
I'm sold.
I suppose you'll want a commission so you can add to your wardrobe?
I'm sold.
All donations to the Get Crusty Back On The Road Foundation gratefully accepted
Red1
212
296
Emerald Qld
Hi all. These are ours. I put one on each bunk for the kids and one at the end of our beds. The way they are it doesn't matter that they don't occelate. We get plenty of air.
MDS69
735
806
Has anyone got or seen the Aldi ones coming up for sale Feb 18. Sorry no link, just saw them on a Jayco FB page.
whooo...my life is fulfilled.
12v fans and Aldi.....I'll have to allocate some time in my busy diary.
Thanks for that....I can't see them advertised on the Aldi site which I assumed was nationwide. It only show specials till the 11th.....do you have special info @mfexpanda ?
These look good! And a good price.
Reactions: davemc
Good on her.....we live in an area where catelogues don't get delivered so I'm like a kid in a lolly shop when I get out and spot one....looking at the website is just not the same
or as up to date it seems.
Reactions: mfexpanda
