16' Series Pop top roof skirt
MarkAW
Point Cook
Hi
We have a 2017 Expanda outback 16
49.4 we've had since new
Recently noticed some cracks on the pop top roof skirt....if that's what its called.
Basically where the springs in that lining are located.
Has anyone replaced and is it a big job DiY
Any feedback appreciated
20,117
Have a close inspection of the cracks to see if they a just surface or wear marks, if its starting to flake off then it will only get worse, some vinyl repair glue, tube stuff can hold it off, if it looks like age is showing and you think it needs replacing then I would pop the roof up, then tie the struts end together, ie" top end to bottom end on both sides to make sure the roof doesn't pop up higher, next up unscrew and remove the skirt carefully, with vents closed then take it to a Motor Trimmer/ Canvas repair shop to get a new one made.. You can then spec a better vinyl and certainly better flyscreen ....
You should be able to close the roof if you did the strut tie offs properly though when lifting it again keep a good hold in case your tie offs let go and in both cases be wary of the load from the awning it may cause roof to skew to one side ....
20,117
Not really just fiddly, some times the silicon patch will last years, well I found it did on awnings ................. I can't remember if they are in one full piece or not, if so then you would have to cut it in half to get it off as struts and internal braces would be in the way, get new one made with a velcro joiner ....bluddy hell of a lot of screws I do know......
