Being home is great for a while but the list of maintenance jobs just seems to be endless sometimes. Thought I would keep a record in case they are useful.
I've already replaced the awning fabric and hws relief valve...
The fridge chimney plate...thing keeps breaking so after several repairs I found the external hole is probably cut too high and the 90' elbow weighting the external pipe down too much. I cut a small ring spacer so it sits higher on the chimney...
Cupboard shelves are a ongoing source of entertainment so started making my own brackets with 3 holes for more grip. Also adding brackets under the shelf which being really awkward, can see why jayco don't...
At least you can't see this one...
This cupboard is much improved with relocated light controllers and my more streamlined brackets. Just need to cover that hole...
Spent a wonderful afternoon removing the failed (1 year old) solar panel and glue from the roof. A new, rigid 200w is on it's way
Then my job from hell. I didn't like the drum mounted jayco leds so decided on rgb ones tucked up under the awning. Had to relocate the channel screws , fish around for the power cable tucked behind that tiny hole. Make a water tight box for the controller because I cant mount it inside easily, redo the control wires to get rid of that 4 pin plug (the controller wires use different colours so red to blue, blue to red, white to green... gaaah. But it's working now...
Sounds like a conspiracy theory to me, how could such a thing happen in the RV industry.......
