Way to go @macca the three gang plates & switches are available through Coast To Coast RV, the plates are only available in beige for extra low voltage so you may want to also purchase the beige mounting block to match, I did a few enquiries and found out Jayco purchase the switch plates and mounting blocks in bulk from CMS Electracom and purchase in batches of 30 000 at a time that's why they can get white, because of their bulk ordering. So that explains why the electrical fittings in Jayco's are all white.@gwadir , My last van we only had one strip and it was fine. I will order a triple gang switch front and extra switch, that way I can turn off the normal outside light off and on by itself.
Thanks Dave, I will pop into Jayco spares, the guy there normally just pops out the back and takes stuff off the line if its not in the shop.Way to go @macca the three gang plates & switches are available through Coast To Coast RV, the plates are only available in beige for extra low voltage so you may want to also purchase the beige mounting block to match, I did a few enquiries and found out Jayco purchase the switch plates and mounting blocks in bulk from CMS Electracom and purchase in batches of 30 000 at a time that's why they can get white, because of their bulk ordering. So that explains why the electrical fittings in Jayco's are all white.
Dave
@rodney , sorry what washer are you talking about? Cheers GeoffHave to say after seeing this layout in the flesh it's not bad id like to do quite a few mods do you have a pic of were the washer is?
