That looks awesome @rojoberry, not sure about your top bunk but ours has a limit of 70kg and Jayco would not do inner spring as it adds to the weight.....maybe something to keep in mind.
Cheers.
Cheers.
Hi jvp. Gavin was partly correct; it is a weber cover but no weber hiding underneath. Its a mod suggested by my wife's cousin when I was a very new van only and very naive. In hindsight, it probably was not a good mod due to the negative effect it could have on towball weight. It's a mod to carry the spare wheel vertically mounted and also to carry a bike rack for a couple of bikes. Haven't used it for bikes yet. Thinking now it could be a good place to locate a flat surface to sit a small BBQ. Will take a photo and post it when I can.
Cheers.
I sit/strap my hoses on top of the spare wheel.Find it a perfect fit and a good protection for the tyre.We found the spare tyre was the perfect size to fit hose bags with an occy strap or two
If you do find a way I would be very interested, having the same model and the same problem.Battery Access --- My battery lives in the bottom of a cupboard on our 14-4-3 and is a big pain to get to when the van is in the shed as I need the roof up to open the cupboard door. Has anyone fitted an external door so entry can be gained from outside ?? I suppose Camec does doors to fit. Haven't done any research just had the idea while fixing my brush cutter.
I have an AGM battery so acid leak is not a problem, but I don't really want to put it under the seat as that space is already used for storage of our gum boots plus a few other odds and sods. I may have to modify my wardrobe shelving to make it easier to get to the battery.Had a quick look today, it looks doable to put the battery under the seat but it has to wait as I'm doing the Mark III version of my stone guard, first 2 didn't quite make the grade. Thinking I will box the section in a bit and line it with rubber or plastic as I have had battery acid in the battery box before, probably from my very steep driveway. Should be able to get to it in a week or so, might have to do some beach fishing for a few days.
Hope I remember them all
1. Cheap and functional water proof bed ends
2. 200w Solar panel
3. 32" TV & Mount
4. Sony DVD player/Radio with 6 x 9 Pioneer Speakers
5. Spare wheel mounted underneath
6. Box on drawbar ( Gas Bottles Moved to fit)
7. Bike rack on Drawbar
8. LED lights swap
9. LED Strip to outside
10. LED strip under overhead cupboard over Table
11. Second Battery
12. 600w Inverter
13. Through wall TV/ Satellite cable connectors
14. One Key fits all (Work in progress)
15. Shelf in cupboard
16. Dinette Bed conversion
17. Vast Satellite Receiver mounted in cupboard
18. 12 pin plug fitted
19. Paper towel rack moved
20. Antiflap kit
21. 12v USB charger plug fitted in Cupboard
22. Wireless Rearview/Reverse camera fitted (Failed yet to be rectified)
23. Non return valve fitted to hand pump
24. Under bed cupboard handles removed and modified (after they broke on 1st trip)
25. Toilet roll holder in bathroom
26. Soap dispenser in Bathroom
27. Switch cover
and more to follow for sure
Capt Gadget - do you have any pics with what you did with your vast box putting it in the cupboard. Just fed up with all the leads, etc sitting around taking up bench space
Through the wall one for the TV and the other for VAST the original TV plug is still there on the other side of the van but is a waste of space due to the huge amount of lead loss of the cable running from one side of the van to the other
From the inside through one of those desktop plastic cable thingos from the hardware store
Then it just sits on a shelf in the cupboard the VAST box and the TV both run off the 600w Inverter stuck to the back wall of the cupboard through a plug in RCD and 4 outlet power board so they can be used off 12v as well
Nah TV is only a last resort for crappy weather, If we're away in footy season and want to watch the Game there is usually someone else with us that can plug a telly in outsideSo you don't move your Tv outside?
