Thanks @Crusty181. What type of fuel tank have you got and where is it installed?Good work. I think you might struggle with a quick connect, the hard fuel line is about 1mm and all the factory connectors are just shorts of rubber fuel hose you jamb the fuel line into. If you ran the exhaust and pointed it toward the off side, regardless if it reached I think you be ok with the fumes so long as it was pointing that way.
