Due to limited space in the engine bay of the Ranger the 2nd battery is in the tub. Firstly I had Ford turn off their so called Smart Charging system which now charges at old standard voltages. From the main battery I have a feed going into a plastic box tucked away at the back of the engine, passenger side. In that box there is a manual isolating switch and feeds a Redarc Smart Start isolator that kicks in after the engine has been running for a short time. Via fuses this then feeds 2 6B&S twin core runs to the rear. One goes straight to an Anderson Plug at the towbar for the van ESC. The other feed goes to a Redarc BCDC charger then via a fuse and into an enclosure that is clamped down to a sheet of formply that sits on rubber matting. The enclosure has a 100Ah AGM in it and then feeds a fuse panel and a Baintech panel.
http://www.baintech.com.au/shop/product-range/power-panels/baintech-universal-panel-ciga-engel-usb
Via appropriate fusing there is a feed from the battery to an Anderson Plug on the towbar for van power.
Still deciding on a really suitable enclosure in the tub for these items as I have yet to decide on whether I might get a Brown Davis long range diesel tank to sit up against the front of the tub. At present I have a gutted out microwave case that faces upwards and the battery fits perfectly down inside it with the fuse panel, Redarc BCDC and the Baintech panel screwed to the outside. As a replacement I'm considering an unused computer tower case that seems to have the right dimensions.
The advantage of the Redarc BCDC and similar is that they can properly charge a range of different battery types other than standard lead-acid ones. It can have a solar feed in to it but as yet I don't have a roof rack to mount one on but I may add an Anderson Plug connection to it to so that the portable panel can be used to keep the battery charged at free camping places.
Like others here most items, especially cables, were sourced from autoelecau on ebay.
