A nice cloudy day that wasn't hot recently was an ideal time to do the dreaded bearing/brake/wheel rotate to Big Mal, what a pain that is for an old coot, about 8K km since last time, near enough, brakes got about 1 click each, bearings not a wobble so very happy since last pack which was when I did the new magnets and shoes, whenever that was.       Tyres rotated and the rear ones do get a hammering on this suspension set up, they are 6 yrs old and have a good amount of tread left after probably 50/60K odd km but new ones next year, this time going for Bob Jane J-Trax LT's in 265 75R16's, price is good and seem to give good life by reports, Geolanders have been great but just way to expensive now and as the Jeeps Geolanders will probably need replacing at end of next year, the J-Trax fit the bill,  I hope .... still over a Grand to shoe each vehicle so will need a generous tooth fairy .............. Been quite a few years since underneath got sprayed so decided to give it a recoat, didn't get far with it, got the suspension recoated and the rest will have to make do, poxy job...
      Some new insulation on a couple of water lines underneath is needed as the old AC pipe lagging has rotted away and the quicker the HW gets to shower the better for all concerned ..
     New gas piggies and regulator made an improvement, gas lasted longer and no faint gas smell at times.............. Lithium battery is working nicely and my diy settings on the Epever appear to work well as it charges up happily .............  Water pump clean up seems to have done some good, not as noisy as previously and reverse flush of water lines can only be good, at 12 yrs old it needs special TLC every so often.... Every so often I will pull something down for a clean up....... also a good walk around after rain driving, any rivet showing a rub/dirt streak gets removed, silicon in hole and a new rivet in place to stop any possible leak.
Awning upper arm brackets need a mod but haven't quite figured it out, clinker type cladding makes things difficult  ............ Some 3mm alloy plate shaped to fit the wall contours is on the books as being the  ideal choice and with some off cut wall panel I'm hoping a mate of mine who is very OCD can knock me a shaping plate up from timber so I can form the alloy over it .....................   failing that 2 bits of 5mm welded at the edge to make a step then some creative grinding work....
  The fun never ends ...............................
