Give him timeIs that it ? Is that the only pic your going to post ? Come on @Drover you we love pics
Give him time![]()
Yes I just saw that
 but there is only 1 extra pic Looks Good. how did " Big COL" handle " Big Mal" on the way home??? and yes more pics
A great story of what can be done if you know what you are doing, and you know it is done right when you do it too. Sounds like you stumbled onto a great deal. How long did you keep it and did you have any other problems before you upgraded?? Very keen to pick up on the history.First post here, I aquired my 14ft Expanda last November, we were coming back from Warbirds at temora with our off road camper when we discovered this 2009 14ft expanda which had never been used, I kid you not it didn't have a mark on it, gear was still sealed in the bags, no scuff marks in draws and the toilet was still in the plastic bag so to speak, the stove had no marks, still with tape over some bits.
We bought it and towed it to QLD, 400km all went good but due to a problem with the Jeep we never got to go camping until Jan so I had plenty of time to sort things out, beside it was too damn hot.
The rear of the fridge wasn't finished off (as usual it seems) the bench top got bloody hot as and the fridge just didn't want to cool down until I added some more insulation on top and paneled the rear up so the heat was directed straight out the top vent, works damn fine now. It had never been used on gas, sure does stink for awhile.
Found my TV plugs worked sometimes, pulled them out, found they were not done up and the 12V connections were dodgy, I then decided to go over every electrical connection I could find 12V and 240V, tested them all 240 thankfully had no faults or potential shorts, 12V needed a few connectors replaced, fitted by a 12 yr old I think.
Extractor fan over stove, vented into an empty space then vented via a small hole to the cavity behind the clock which then vented to outside, crap idea, made a fitting to fit the vent on fan then used a pipe to run to the outside vent, far better for things.
The plumbing under the van looked like a dogs breakfast so tidied it up and fitted chaff pads where the hoses ran thru the body and clamps, wouldn't have been long before things would wear a hole. Some hoses just had zip ties holding them, in process of replacing them with better fastenings.
Since the arse end was dragged getting into my place, steep rural driveway, just a bit rugged have to use low range actually, I rolled the axle which gives it plenty of clearance and tows behind better than before, much easier to get underneath also. Nice workshop makes life easier.
Fitted a battery and wired up so I can plug my solar panels in via an anderson plug outside, checked the power output and all is good and shouldn't fry the van set up.
Big pain transfering rego from NSW to QLD but luckily in Toowoomba there is a fella who does the all the paperwork Gas, Compliance, roadworthy etc, so no stuffing around, just have to fit my Trigg hitch and thats should do it for awhile.
So it's a great little van, really brand new as I have all the new van problems but I get them fixed properly, by me instead of some apprentice. Folks at Temora had said to us " Jayco is the A Mart of the Van World " and I think I agree, look great but their attention to detail is wanting.
I had one of these as a work car, picked it up brand new and when it was due to come up for auction was going to buy it. One of other blokes took it on patrol and bogged it on the beach, 4 ft of salt water over it for 2 tides. That was the end of that plan"It's wet so dug out some old photo's to post on some other sites and found this one, Coloured Sands Rainbow Beach 1991 nothing to do with my van but it's such a great place. This old truck carted our family all over the place for many, many years just tenting it with a trailer to cart the gear as the truck was full of kids and the odd dog. Great memories.
I'm that old when my granddaughters School had a session on fossils they took me along as an exhibit! I loved that cruiser, mind you the Qld Government supplied it along with a 21ft Savage Marlin with twin 135hp outboards. I was flasher than a "Rat With A Gold Tooth"!You must be an old coot @Frog to get a brand new one, i now when they came out they were more than I got paid for the year, great truck to have did many miles in ours until old age ( 28) and a slight fall saw it put down.
Hi @Drover, this seems like the goods, I'm thinking I could possibly get two in, side by side, & common them up. I can't see from your pics what you used to hold them up in place, van you advise please? Also did you end up putting an S bend or hepvo valve in? I see you get down close to my way (Coffs Harbour) from time to time. Red Rock & Corindi are both pretty special places hey?Grey water tank all fitted, holds about 40 lts, was hoping for more but not hard to expand it. Should be good for a day or 2 at those stops that require it, when not needed just open the valve and it flows as normal. Remove end cap if cleaning needed.
Haven't fitted any S bends will see how things go but since this unit can be cleaned easily unlike using other tanks I probably won't need them and it has a breather vent fitted also.
The fitting on the valve will have to be changed when I find a less bulky unit but beggars can't be choosy.
Just used 150mm PVC pipe and various poly/pvc fittings.
 Hello AusSteve, we did this on our 14.44.5 after reading Drovers post. We didn't put in an S bend, water not in there long enough to cause any problems. Wife has a very sensitive nose and never had any complaints. We also re-routed the drain pipes from the sink, shower and hand basin so there was a more direct flow to the tank, they all empty quickly.Thanks for this Jeff, I'm hoping to put mine in further forward so it has minimal impact on ground clearance and departure angle. Have you found any problems with ground clearance or departure angle? We will be doing a lap starting next March that will include lots of off road stuff so I need to have the clearance. This could mean putting the(m), tanks, between the East/West chassis rails and possibly having to have the feed going into the bottom of the pipe.View attachment 58465 View attachment 58466 View attachment 58467 Hello AusSteve, we did this on our 14.44.5 after reading Drovers post. We didn't put in an S bend, water not in there long enough to cause any problems. Wife has a very sensitive nose and never had any complaints. We also re-routed the drain pipes from the sink, shower and hand basin so there was a more direct flow to the tank, they all empty quickly.
Another day of fun, fitted 2 fans to the fridge and what a change they make, after about 1.5hr the freezer was showing 0.5c, 17.5c inside, outside temp was 28c, 3hrs later I have -12 in freezer and 11c inside with 4c just below the fins, outside temp is 26c, got it set on 7.Using a temp probe that I used for work so it's calibrated, have left it running for the night to see how it goes. Put the thermo switch on the fins but using a 70c unit took ages before it kicked in so moved it to the pipe that runs across, it's damn hot and fans kick in and produced the goods.
Used a S/S spring clip to attach the switch that way I can move it if needed.
Fans running just before I fixed them in place, if fans craps out can be replaced without dismantling everything, glad I thought of that, nearly stuffed it. Used a bit of conduit left over from an A/C fit out works a treat, did it the Jayco way, couple of screws and heaps of silastic and a couple of zip ties.
