Should have its just a standard threaddo they have the right connector seeing Bunnings do not sell Weber?
Take yours off and go to Bunnings with it to compare the thread sizeBeen a few threads on here and elsewhere.. two different connectors that look the same
@Ligedy might be able to explain
Had trouble finding the 3m hose at masters (which deals weber). Ended up getting long hose and most weber stuff at Rays outdoors where you also get credits off the next purchase, whatever that purchase may be. They also have caravan accessories, priced ok.The two different fittings are 3/8"SAE and 3/8"BSP. You require the SAE one for a weber.
The SAE female will screw on a BSP male fitting but is loose and may "jump" the threads when tightening (No good at sealing)
The BSP fitting will not screw onto the SAE one at all!
Hope the above helps But as @mfexpanda said..... Speak to @Ligedy and he'll set you right.
And looks like will finally get to test out the weber q. Brand spanker Starcraft OB 22.68.1 being picked up Friday at 9am after the mega wait!
Yes, and we've been looking at the starcraft so long I don't think too much has changed since yours. I think maybe the fridge and aircon has changed. I haven't seen one with optional composite walls yet. Now that would be a change but me thinks good ole aluminium is lighter and I like the look of it!not long now @Gilmorehappy you can almost taste ityou know we want pics be interesting what has changed since our one
Hi McKenzie yes yours is only a few weeks off? Early dec? So you know the feeling of anticipation! Can't wait to post some pics this weekend showing it in the driveway, and fitting it out with all the new chattelsSounds a bit like us @Gilmorehappy.
:whoo::whoo::whoo::whoo::whoo:
and @davemc On the 22.68, the rear bottom bunk has an alternative option of a hinged bunk with storage underneath. You can also get external access to this compartment from an external hatch, or from the inside with the bed on nitrogen cartridges. Ours is still going to be the small cafe dinette bed converter ( not storage compartment) so the boys have somewhere to sit and chill.The walls look nice saw one at the show..that and outback we would of gone for if I wanted to spend extra $'s and wait.. Although would of weighed more.
Main differences I have seen are the strip lighting/leds and lighting above etc basic design the same.
