Electrical BMS and Battery Upgrade .... Quandry
20,087
Of course I forgot you had split it all up ..............
I'm probably wrong but I think if you have 2 separate strings in series but joined together individually at the controller then its series connected in parallel so the controller would only see the prime voltage being 44v or whatever ,2 x the VMP of one string on the controller screen not 4 x VMP .......... all your panels would have to be connected in series and run to the controller for you to see a higher voltage ...... So a NEG of one string connected to POS of the other string with the other Neg and Pos connected to the controller ....... then again if all wired together and just a shi*ty day,shadow could have knocked out a set or they are only making 11 volts each ...
In vans I can't see a need for series, van cable length is not really an issue, higher volts means less amps which means less charge capability and when I have tested mine the voltage drop is bugga all, even with the 8B&G 10m and 5m extenstion cables run out but the amps produced by the lower voltage is greater by far than with higher volts and AMPs are what gives the battery its grunt ......................
So all in all everything good, should have stayed out there I think with this weather......
425
You are right Drover...I did some further research and found that by connecting 2 strings of panels connected in series, the MPPT will only "see" a primary string voltage of say 43v, but will "see" the amps being produced by the 2nd string and take advantage of that.
When I connected the 2nd string I did see the amps input jump a little...the MPPT would only have been using what it needed I guess to stay within the charging parameters for the Lithium batteries.
As an aside I originally set up my portable panels in series as I would often have them set up up to 30 metres from the camper trailer I had at the time...due to potential shading.
I agree, Parallel connection is often better for roof mounted panels yes, as even if one panel is partly shaded the other will still produce power, rather than the situation where if one panel of a series is even partly shaded it effects the whole string's output....I just prefer series connection though...:)
Just adding, I was seeing 43v - 44v at the MPPT with the two roof panels in series which I was reasonably happy with, even though the new panels will allegedly each generate 24.1v at open circuit...the MPPT doing it's job?
What was weird though, and I didn't really have the opportunity to spend time on it, was when I connected the portable panels as well out of curiosity. Though the day had moving cloud cover...with the two sets of panels both wired in series and connected at the MPPT, input, I thought I would see up to 80v at the MPPT being each pair would be sending around 42v - 44v each to the MPPT....but I only saw around around 43v input, with both sets or just one set.
Not sure whether the MPPT was "clipping" the input voltage as it wasn't required?
I really need to have a decent day without clouds moving over to muck about with the set up and try to understand what is going on.
@Hitting the road , I note that you have 2 X 200 w panels on the roof in series which will give you around the 42 to 44v you see at the input of the MPPT controller. You also have 2 X 200w portable panels available to you. When you also connect the portable panels which are in series, to the input of the MPPT controller ( to the same points as the roof top panels) all you are doing is connecting 2 x pairs of 200w panels (in series) to a PARALLEL set up of 2 x 200w . So voltage will still be at 43 to 44 volts but AMPERAGE will be the sum of BOTH outputs. (a series parallel set up) The only way to increase the voltage is to connect the two sets of two panels (total of 4 panels) in SERIES and that will give you in excess of 80 volts but current will limited to the lowest performing single panel). That would mean disconnecting the input wiring from one set of panels and splicing in the other set (in series) - a messy arrangement!!! The MPPT controller will give you the MEAN AVERAGE VOLTAGE of both pairs of sets of panels, both roof top and portable when connected in parallel. If your SERIES connection of all 4 panels does exceed the 80 volt limit, most good MPPT controllers will limit the voltage to a safe continuous voltage within the specs.
20,087
All you need to do is set up some Andersons near the controller so you can arrange the input to the controller to one string of panels in series and problem solved when you want to plug in some portables, I have mine set up so I can shut down the roof and just run the portable if need be ...
Your right about the MPPT unit deciding how much power it wants at the time, running the battery down and plugging the fridge into the van power showed me how my set up worked, the MPPT drew enough to cover what the fridge was taking from the battery plus a little bit for charging, when I fired up TV, radio and STB to draw another 4a it just cranked up a bit more to cover it, I was expecting to see massive power drawn from solar but no just enough to cover needs ... did work out that if I ran out of gas one morning I would have a few hours to chase up more and the fridge would be okay to run off van for as long as the sun shone.... cheaper than running the genny for sure.
If I had matching panels on my roof I would do some trials on series/parallel but with 2 x 110w @ VMP 17.6v/VOC 21v panels and a 200w panel @VMP 18v/VOC 22V I know it would be no good, so parallel is the go and with a max of about 23w from them combined in parallel its cool... I thought the 200w job being 13 yrs old and was about done but last meter I put on it was still throwing near specs so getting a roof of identical panels is not planned now, paraellel shunts plenty of ampss so would probaby stay that way even with identical panels ...
425
Thanks Boots, Drover...I had considered setting the system up so that I can run roof, portable, or both...but hardly worth it really. I can unplug the roof panels at the MPPT if I want to use just the portable, or the roof set just by not putting out the portable set up. And..after some extra research found out why as you both wrote I am seeing the outputs I am.
Happy enough though...
20,087
Yep, if it works then why stuff around anymore ..................... took a couple for years for me to redesign my circuit panel, new circuit breakers and stuff , it was the new air compressor that brought it on as it blew everything, mongrel thing wanted more juice than I had allowed for, so now the pump will melt before my board sparks up ..................... though now having the ability to just flick a switch and shut down the roof panels does make it easier for maintenance or breakdowns to disconnect without shorting something out and battery disconnect just takes a micro second .......................
Good to hear you went away and didn't break anything ...................
20,087
Actually it wouldn't need much, the MPPT controller has an anderson hanging off the POS terminal to match up with an anderson from the roof panel feed, when connecting the portable you would just disconnect the roof POS and plug in the NEG from the portable and connect the portable POS to the POS anderson from the MPPT and bingo one string but then if everything is inside its a massive lot of stuffing around.
425
The connections I have are inside the van...the MPPT I mounted in the drawer under the dinette beside the fridge...there was no where else to put as the all the space under the dinette is taken up by the two batteries, the BMPRO BMS, the Victron charger and the internal wheel arch...so I have the MPPT mounted in the drawer right beside the batteries with sufficient cabling so I can just pull the drawer and look at what is going on charge wise.
I have an Anderson plug in the input of the MPPT which connects the roof panels, along with the cabling from the external Anderson plug for the portable panels in the same input.
So, to disconnect the roof panels I can just open the drawer and pull the Anderson plug...external panels are unplugged from the external Anderson plug up front...pretty simple.
3,040
3,414
Hi Mate
Last year I fitted a Victron Smart 50amp MPPT and made the BM pro redundant for any charging purposes . Just before easter I ditched the original panels and fitted 4 x 200 watt high voltage sphere panels in series, as the run through the roof was long in 6mm auto wire. Results so far are very impressive.
Just love the Victron stuff, it works so well. The app is the best I've come across and just works. The separate's give you redundancies, about the only criticism is its size and lack of IP rating.
4,416
Hi Mate
I love Victron gear, even though it’s not “hi tech” it’s robust and super reliable I’m using their charger on a 200Ah hybrid battery and a Victron mppt for the car aux battery only because I changed to Redarc mppt/dcdc in the van. Keep it simple works for me!
20,087
While looking for info on cable/distance loss I came across this interesting site, https://www.solar4rvs.com.au/buying/buyer-guides/ultimate-dc-cable-sizing-system-calculator-for-rvs/ haven't had a play yet but did look like an interesting calculator ............................. might feed my system figures into it to see but I may not like its answer...
I use a simple calculator to work out cable size compared to voltage shunted down a line to minimise voltage loss. ..
A great guide to the "ultimate" wiring sizes and voltage losses. Cranked in figures for my setup as follows: 3 x @200w panels in series with Vmp voltage from panels at 18.0 volts (mine are more like 19.0 volts with the Schottky diodes), and at a distance from MPPT controller at 20 metres. Loss was very low but would have been better with 6 B&S cable when I am using only 8 B&S. Loss between controller and battery at less than 300mm with 8 B&S cable was almost nil. A 40A fuse in line seems ok too seeing MPPT controller is only rated at 30A. I don't know about a 400A fuse just between switch and house battery for my simple setup though!!
20,087
Yep, @Boots in Action , I tapped my details in and Ive used 8B&S on everything but my distances are single digit M so stuff all loss ....................... I have got an 80amp breaker between the battery and buss bar and a 40 on the panels, even the extensions 5m and 10m put into the system the drop is not worth worrying about.............................. at least its confirmed what I found by putting a meter on them way back .....
