Hey mate
I have a 7 pin plug from car to van and then the anderson. The anderson does basically replace the hot wire in the 12 pin from my knowledge. The beauty of the anderson is a much larger cable and quality of power for charging the vans battery but more importantly to keep good power to the fridge whilst it is running on 12volt whilst travelling.
And yes so you can plug the solar straight into it to charge the van back up.![]()
I have Anderson, 12 pin and Solar on my 16-49-3, (all factory fitted) As we have the 150 ltr fridge the 12 pin "Hot Wire" runs the fridge the Anderson goes straight to battery.
Hey guys, did the sign off on our 20.63 0B today. We went for the slide out on the original draft and when the drawings came out were told that there is possibly no access for space under the seats in the slide out version, whereas there is in the non slide out item. Tried to change it back to non slide out as an "as built" as it seems a pointless exercise to lose all that storage for a nice to have item costing an extra $2.5K and they flatly refused to make the change. Took the shine off the whole thing with this attitude and it wasn't the only issue that ticked me off. A lot of the modifications and additions that others seem to organise with the factory on this forum also "could not be done". Anyone else bought the slide out version and does it have under seat storage or not? I can understand the reasoning if there isn't, as without certain factory underseat modifications that will be easy to do with a bit of thought, badly packed items stored under the seat could jam the movement mechanism in theory. No doubt I will make it work and modify it myself if worst comes to worst.
Outlaying so much folding stuff you need to feel as if your business counts. Currently I don't get the warm and fluffies from Jayco. It seems everything is just too hard for them and all they want to offer is bog-standard fare. For a $60K spend I was expecting a bit more enthusiasm from the dealer and manufacturer.
Hey Peakay..... Looking Good!
What will you be towing it with?
Ordered today!!
Thanks for all the input guys, i gave each idea some thought, used some and didn't others.
The shopping list.....
I was able to buy local in the end as they were substantially cheaper than Melb and Geelong! Thanks again for all your help!
- 20.63-1 without slide out (it just didn't seem to give any extra room as the 300mm or so that it extended out was taken up by the 300mm bigger lounge)
- extended drawbar
- gas bayonet - they won't fit 2 any more due to gas regs
- extra light forward of the main door
- jockey wheel moved to inside A frame
- external shower
- 150w solar kit
- antenna and provision for tv
- privacy screen
- few extra 12v points
- ESC
- shelves in the robe
- Full annex
- Drifter control panel
- aux battery
- stuck with the double bunks and got the bed conversion for the main table
Many congrats indeed and happy camping! Can I please ask what the rational was for moving the jockey wheel inside the A frame was? Also putting in extra lights - did you look at this in the dark and work out that there wasn't the light you were hoping for? Just not something I would have thought of asking for - great pick up!
on the space under the seats, we pick our new 20.63OB on the weekend, finally after a 4 month wait!!!
i requested a hatch (cost about $140) from the factory to access the under lounge area from the outside. i checked this out last weekend and although the battery and waterpipes run through this area, there is still some useable space, without having to lay over the table, pulling up cushions.
