We have the new 20.63-1 with the slide out and are very impressed with it. I would highly recommend the slide out but yes it is a lot of money but we are very happy we decided to go with it.
I went with the on road van this time but upgraded the wheels to 16 inch to give a little more ground clearance, we had a O/B with our last Expanda and found it a little bit high and we don't do much off road traveling either.
Power points and 12 volt sockets are standard to both bunks. Fitted four bike carrier to rear wall and external shower to R/H wall.
I put the drifter control panel in and it has many new features to it including integrated battery and pump switch.
I had a large external locker door fitted to access the space under the bottom bunk and this works really well for storing annex and flooring, I deleted the draw under the bottom bunk to give more room for storing from the external locker door.
Only concern I would have with your order is the extended draw bar to carry your motorbike this would make the ball weight very heavy.
I tow with a Q7 and is awesome. Best of luck with you new purchase and I'm sure you will be more than happy with it.
