19.61-2 Journey Outback
Base23
467
1,088
You are welcome.
Install look good and glad you are happy with how it tows.
Definitely seems to tow a lot smoother but the best bit is when you can level it so easy when parked on a uneven site.
Looking forward to seeing the control system and what you do.
Reactions: achjimmy
3,032
3,404
Slammed as the kids say
Side to side variation . The bar at the top is the level garage door
Raised
Reactions: Base23
3,032
3,404
So cleaning the van to put it away I had two ice trays full of defrosted water in the freezer. I’ve driven about 45km including a few pedestrian humps and in and out of a servo and the trays hadn’t split a drop !
3,060
2,345
Can’t work out Jaycos third tank plumbing . Not sure the pic is clear enough .
They have balanced the two front tanks with the pick up line . Was getting air in the line when using front two and they are not drawing down evenly. Would have thought you’d balance at the bottom ?
Anyway plan is to isolate front tank and fit seperate pump and filter (again) and have as a dedicated drinking only ! The adventurers are Plumbed like this and @Crusty181 gave me the idea when he mentioned his love of melbourne water :D
Our water here at home is nothing stunning but is clean.
At least they are using black piping now, not the clear stuff of the past.
3,032
3,404
Been a long time since I posted
moved the batteries from under the bed to under lounge
fitted an 1800watt inverter
fitted a JHub shunt to read all useage
fitted A gas heater
6 B&S from drawbar to battery direct
onboard compressor and air tank With self leveling arms and control system
slide out pantry drawers
fans
tv bracket And a few more bits.
completely loaded to the hilt , 3 tanks full and a couple of extra things thrown in for the test and she went bang on her ATM of 3020 so well done Jayco. That should shut up the naysayers!
since then have culled out a heap of stuff (3 hose reels , 4 power leads, doubled up kitchen stuff etc etc ) and took it to an RMS engineer who has rerated it to 3500kg ATM so I can add a grey tank and few other options but nothing that should take me to the max again . except I am turning the front 3rd tank into a drinking water only tank I’d have turned it to a grey. On recent trip I never needed more than one tank. I think it was @Crusty181 that mentioned on his big lap water was never that hard to find ?
fitted A gas heater
fans
We certainly had to keep an eye on it, but wasnt an issue. We consistantly carted 70ltrs in jerrys and never used a drop of it.
19,864
2 tanks, travel with one full and a couple of 20lt jerries if need to top up mostly will fill both if going bush but can make a tank last a week if need be.....just handy to have portable if needed .....
Reactions: WHHEMI
