S + B's Starcraft 17.58-3 Outback
17triton
3,717
5,438
Ballarat
I am seriously considering something like your custom build on the front our expanda mate.
Wondering, what was the idea behind what look likes excess plating / bracket along the draw bar, instead of just enough to mount the SHS on? Was it simply for extra strength? And if so do you think (or perhaps Mrs Structural Engineer) it was required in the long run?
I made the bottom plate to share the load along the drawbar rather than putting the stress on one small part of the drawbar. It worked really well and the people who bought our van loved it. It might of been a bit of overkill but it was very sturdy and I like the fact there was no welding to the drawbar to weaken it. (Maybe I learnt something off the Mrs lol)
Reactions: bloke
bloke
101
211
Bendigo
Sounds good. I too like the idea of no welding, as everyone warns you off welding onto the bar.
I think I should be right for a similar custom build between our bottles and the van. I may have to make it a bit higher to clear both bottles and also the jerry can in the middle.
Time to get the tape measure out! (tomorrow :))
17triton
3,717
5,438
Ballarat
I had the advantage of only one gas bottle so I could clear the bottle by how the first bike was put on. I couldn't go too high with the drop down bed but you will be fine with the Starcraft.
bloke
101
211
Bendigo
As long as it is solid, and lower the roof line (dropped obviously), that is the main restrictions for me at this stage.
Reactions: bigcol and 17triton
bloke
101
211
Bendigo
@17triton what size SHS for the cross frame did you use on the old expanda bike mount? 40x40x2? Something similar?
Also, what size flat plate did you use along the draw bar? Looks about 100x8mm?
3,031
3,401
Bloke not answering for @17triton but you will most commonly find 40x40 is 1.6 and 100 flat bar either 5 or 6 mm
bloke
101
211
Bendigo
So the last couple days have been busy, smashing out the bike rack plan. Really wanted to get it done ASAP so that we can take the bikes on the first trip next week. So I bought a pacific bike rack (30% off at Anaconda) yesterday, then dropped into the local steel place and got the following items:
100mm x 10mm flat steel (for on top of drawbar)
40mm x 8mm (for underside of drawbar)
16 x 1/2 inch long bolts to clamp the above flat steel around the draw bat (32 washer to suit)
50mm x 50mm x 2.5mm square tube for the hurdle between the drawbar a-frame
A quick drive home, collect the van and around to a mates place who has more space and more gear!
Guided by @17triton 's pics from his previous van mod, we got stuck into it. Some photos below do the talking.
It is all mounted and finished now. The largest bike still sits lower than the van roof line which is great. The metal work is extremely strong, with the only minor flex being in the bike rack its self. The bike rack has a strap attached to the back of it, with the idea that this be attached to the rear of your vehicle (when mounted on a tow bar) to provide extra support. I think it will be more than fine without it, but may look at attaching the strap somehow...
You will see that there is a cut out for the drawbar tap. I was initially going to relocate it forward on the bar, however decided to leave it as it is protected from the gas bottle holder base. Not a bad spot where it is.
The only thing left is to give it all a good paint job.
17triton
3,717
5,438
Ballarat
Well done @bloke looks awesome. Sorry I missed your post on sizes. Mine was the same with the only movement was in the bike rack itself where the tubes drop into the base plate.
bloke
101
211
Bendigo
Cheers mate, no problem about sizes.
Did you end up fixing the support strap to the van at all?
WHHEMI
357
562
Yarra Valley
Looks great at least you see it gone through the rear window ;)
I was lucky saw the bikes almost gone with rear view camera with our rack on back of Starcraft.
One more bump they would of been road trash
What type of rack and what was the problem.
bloke
101
211
Bendigo
Yeah that's part of the reason I went with a front mount design. Didn't like the idea of them hanging off the back.
Sounds like if the rear rack is mounted right, should be fine though.
Reactions: bigcol and davemc
WHHEMI
357
562
Yarra Valley
I have one on our Journey and have never had a problem with it, I have had friends that are following us tell me it and the bikes don't move.
Reactions: davemc and bloke
bloke
101
211
Bendigo
yep 10mm plate on top of the draw bar, and 8mm pieces underneath for the clamping... you made me just go outside and double check! :) whys that?
