12' Series
RM2553 Fridge Options
I do not believe it would be the thermostat. Ian advised to feel the piping above the burner (not the burner itself!) which should be...
Jul 21, 2026
caravans and tugs being weighed
Was sent a Faceache link this morning about checks at Rolleston, doing awareness checks, no fines it seems .... Comments show how many...
Jul 21, 2026
on the idiot box news and facebook ,police in the central Queensland highlands , take Emerald as the centre of that map, are having a...
Jul 21, 2026
Jul 20, 2026
Jul 20, 2026
Bum ...................... I see a drip of water dropping from front of van lower trim to ground, close inspection shows its coming...
Jul 20, 2026
Solar
SOLAR PANELS ? IN SERIES OR IN PARALLEL ?
I’m with you @Hitting the road , all this leaves me behind so I prefer to keep it simple. We barely use our air con when in parks, I...
Jul 20, 2026
Solar
I have always been the opposite...more volts to push the amps. I am certainly no expert, but the issue I have read of over and over, is...
Jul 20, 2026
E
Expanadaman
12' Series
Ok, ran it on gas for 4 or 5 hours at flat out, max cool, no cooling in fridge. Then wound thermostat back to minimum to see if flame...
Jul 19, 2026
Solar
Is that between your battery and inverter ???? ...between the battery bank and the bus bar. Basically I have the 3 x 135amp Lithiums...
Jul 19, 2026
Solar
Its just got to the stage its bluddy rough in a lot of places and does the Brides back in but Ive had a gutfull of dodging holes and...
Jul 18, 2026
Solar
just wondering what is the issue with the Yetman to Warialda road, just bad for vans or bad enough not to take a car? or go the Ashford...
Jul 17, 2026
E
Expanadaman
12' Series
Awesome, thanks for detailed response. The cat pee smell I don't recall running into either in the van or when playing with its back...
Jul 17, 2026
E
Expanadaman
12' Series
Folks, Fridge doing my head in !! Up until recently my trouble free 3 way original had always done its job. Owned van for about 10...
Jul 16, 2026
Trip Planning
Jul 16, 2026
