If you were driving down the road during the day and came up behind Big Mal you would have been hard pressed to tell if the tail lights...
Feb 27, 2026
Feb 27, 2026
Feb 25, 2026
Well Henry has now had the mods done to its Tranny, removed the coolant heat exchanger for the tranny fluid and replaced with 2 air flow...
Feb 25, 2026
It is thankfully, of course totally different to the Grand in many ways while it doesn't have the get up and go of the VM it does suit...
Feb 23, 2026
Thats why I prefer parrellel on van, short runs so no need for extra volts, I'll take the Amps .............................. Using...
Feb 23, 2026
Feb 23, 2026
It's still in my mind to set up house for the genny but in near 10 years ran the genny twice once for about 3 or 4 hours after big...
Feb 23, 2026
@Drover , I always had an idea that the "Pro star" and "Morning Star" regulators were suitable for use with "house" panels as a lot of...
Feb 22, 2026
I could do the thing myself, it isn't difficult, and oddly enough there are even some You Tube videos around explaining how to hard wire...
Feb 21, 2026
Yep...the normal RCD won't work as it should with an Inverter on board as there is no external earth for the RCD to direct any current...
Feb 21, 2026
I imagine the sparky will love that as they seem to shudder at the thought of fitting a genny socket on house boards.. The...
Feb 21, 2026
Have now fitted the 2000w inverter, fused via a 250A fuse direct to the battery leads at the Busbar connection being the Busbars are...
Feb 20, 2026
Feb 20, 2026
Good to hear your new tug is meeting expectations...8-)
Feb 20, 2026
