Feb 20, 2026
Feb 19, 2026
It's all about WATTS Ian. 5.4 amps at 36 volts amounts to approx 194 watts, while 5.4 amps at 18 volts amounts to only half the total...
Feb 19, 2026
Another Dunny Idea ...............
Some camps weve been at nearest dunny could be 50 miles or more away and then some you don't want to get out of the car let alone walk...
Feb 18, 2026
Not a real bad idea if you spend a lot of time off grid where there are no Dump points...for the girls anyway...quite a few vanner's are...
Feb 18, 2026
The only problem twos are the ones that refuse to exit after multiple flushes and a queue of dumpsters cheering on :oops:
Feb 18, 2026
Feb 17, 2026
Feb 17, 2026
Thetford now has a separation toilet, while its not a compost job it doesn't need water flushing, you have a wee bucket and a big Doggy...
Feb 17, 2026
Feb 15, 2026
Starlink Mini ideas.....
More plan changes, you can now get a Gen 3 Standard unit for free, well no rental or purchase required with a 3 tier plan set up...
Feb 15, 2026
3,000km till next service but Supercheap had Penrite 5W40 C3 oil on special so jumped in and got 10lts and an oil filter $124 instead of...
Feb 1, 2026
Supercheap auto, I’ve heard this name somewhere?
Feb 1, 2026
Jan 31, 2026
20' Series
Adding rear locker under bunks.
Just be 100% sure it doesn’t have an aluminium frame inside the walls as a lot do!!
Jan 31, 2026
