gregp's post
Interior
[SOLUTION] Fixing sticky cupboard door latches
Hi again all, I finally got around to working out why these cupboard door latches stick and how to fix and posted a quick video below...
Jan 30, 2026
gregp's post
Interior
Jan 25, 2026
gregp's post
Interior
Jan 24, 2026
Morganb123
20' Series
Adding rear locker under bunks.
Hi team Wondering how f anyone has any sort of instructions or insights if it’s possible to add this rear locker to an existing...
Jan 24, 2026
gregp
Interior
Jan 24, 2026
R
rfox
Interior
Thickness of ceiling
Thanks Drover. Hoping not to have to replace roof. Cross Fingers.
Jan 22, 2026
14' Series
Water on roof
Same here with my pop top JJOB...especially if running the air cond for a while...I always try to leave a few degrees drop to the rear...
Jan 20, 2026
14' Series
Water on roof
Its not just expandas most vans do, my old Tardis was the same and my full size non pop top rig, Big Mal has a number of small lakes...
Jan 20, 2026
R
rfox
14' Series
Water on roof
I really like all but one aspect of my Expanda. The thing I think is a problem is that when you have the van level, water sits on the...
Jan 20, 2026
R
rfox
Interior
Thanks Drover. I test drilled a little hole in the ceiling and it went in about 25 mm before I hit what I think was the outer (roof)...
Jan 20, 2026
Pace's post
Pace's Malibu Family Adventurer 20ft6 (custom build)
Warrnambool 2026. Our best setup yet, will be doing this again. Just line the van with the water post.
Jan 20, 2026
Pace
Jan 20, 2026
I have at last added the 3rd battery to the battery pack in my JJOB 17.55-1. When I originally upgraded the batteries from AGM to...
Jan 19, 2026
I wish that was the case with mine but sadly not ..... you could feel the vane arm grumbling when it should have moved smoothly...
Jan 19, 2026
I was reading a blog the other day, a fellow was having dramas with his Jeep going in to limp mode when towing, took it to a Dealer and...
Jan 19, 2026
