Wondered why the rear water tank was hard to fill...
...only coming up 4 years...lol.
Nov 9, 2025
Thought I'd do some maintenance to figure why the rear water tank was sooo slow to fill...aha... I found Jayco's way of making...
Nov 9, 2025
You should have just called me it would’ve been easier
Nov 8, 2025
Inverter install
There really is no where under this Jayco to mount two batteries that I can see unless major mods were made somewhere. If so would be...
Nov 8, 2025
I thought you had the 100mm version according to your first post on the subject, if it’s 150mm I’ll buy it (the free freight makes a...
Nov 8, 2025
Inverter install
...The hardest is enclosing and venting your batteries . Gotta agree...I replaced the AGM's I had in my Jayco in April 2023 before...
Nov 8, 2025
Inverter install
Remember the new standards/ regs around wiring as well. Major modifications require compliance. I don’t agree with all in the standards...
Nov 8, 2025
Thanks Ian My standard hitch is around 110mm, I’ve been looking at their longer one do you think I could fit my stone stomper to it...
Nov 7, 2025
Is the stinger hitch alloy? What drop does it have? I’ll buy it if it suits my Henry since going with larger tyres the van sits up now
Nov 6, 2025
I may have said it before but this time I mean it "I am never doing anymore wiring on a vehicle ", run my van power lead to the back and...
Nov 6, 2025
Inverter install
Thanks for the replies I think maybe the best way I should go then is have my inverter connected direct to the battery and run the...
Nov 6, 2025
Inverter install
Agree with Drover...that's how I have wired inverters in the past...I used good battery cable straight to the inverter with shortest run...
Nov 6, 2025
Inverter install
A good sized Inverter I would go direct from battery, mainly because you want the shortest run possible with the biggest cable, a high...
Nov 6, 2025
Well its only money, bought a nice, new shiny Stinger hitch for the Jeep back in January, a great bit of kit but it doesn't have the...
Nov 6, 2025
What a unit !
Nov 6, 2025
